Traffic Lights Prototype
My project is a traffic lights prototype. The main objective of the project is to show people how traffic lights work and how Arduino projects can be present in our daily lives.
based in project: https://www.makeuseof.com/tag/arduino-traffic-light-controller
Step 1: Step 1: Materials That You Need
  • 1 breadboard
  • 1 arduino
  • Male-to-male wires
  • 1 button
  • 1 resistor
  • Red, green and yellow lights
Step 2: Copy the Code Below in Arduino Platform
int red = 10;
int yellow = 9;
int green = 8;
int button = 12; // switch is on pin 12
void setup(){
pinMode(red, OUTPUT);
pinMode(yellow, OUTPUT);
pinMode(green, OUTPUT);
void loop() {
if (digitalRead(button) == HIGH){
delay(15); // software debounce
if (digitalRead(button) == HIGH) {
// if the switch is HIGH, ie. pushed down - change the lights! changeLights(); delay(15000);
// wait for 15 seconds
void changeLights(){
// green off, yellow on for 3 seconds
digitalWrite(green, LOW);
digitalWrite(yellow, HIGH);
delay(3000);
// turn off yellow, then turn red on for 5 seconds
digitalWrite(yellow, LOW);
digitalWrite(red, HIGH);
delay(5000);
// red and yellow on for 2 seconds (red is already on though)
delay(2000);
// turn off red and yellow, then turn on green digitalWrite(yellow, LOW);
digitalWrite(red, LOW);
digitalWrite(green, HIGH);
delay(3000);
Step 3: Male-to-male Wires
Make sure the correct male-to-male wires are connected in the breadboard since the breadboard works in a way that all the holes in the same row are connected. Also, all the male-to-male wires need to be in the right entrance at the Arduino to the code work.
Step 4: Resistors and Button
Place the resistors and buttons connected to the male-to-male wires in the same row to make the code work. The button will work as a traffic button for pedestrians to change the light whenever they like. Connect the button to digital pin 12.
Step 5: LED's
The LED's have two different legs, one positive and one negative. The longer leg is the positive and the short leg is negative. Connect the long leg of each LED to digital pins eight, nine, and ten via a 220? resistor. Connect the short leg to Arduino ground.
    • Build a Tool Contest
    • Remix Contest
      Remix Contest
    • Weaving Challenge
      Weaving Challenge
    seamster
    3 months ago
    Thank you for sharing your first project! Welcome to Instructables : )
    Do you happen to have an image of that actual project you made, that you could use for the cover/thumbnail image (to replace that main image in intro)? That would be a small improvement that would help a lot. Just a tip! : )
