Introduction: Trampoline Soccer
In this Instructable I will show you how to make or create your trampoline into a soccer field for little or no cost.
Step 1: Set Up
You will need some type of string and you can see mine in the picture as the goal. In picture 2 you can see the type of ball you need if you leave your goal my size otherwise you will need a bigger or smaller ball. You also must have a netted trampoline.
The one I'm about to share with you is optional but nice if you have more than 2 or 3 balls. It is a net type thing shown in picture 3.
Step 2: Instructions
With the string you have you must go through every so many holes I did ten cause my holes are small if yours are bigger than you will need to go through every ball I hope you know this but we will come back to it later.
Step 3: Rules
1v1- Each player is the gale and the outfield player.
You can only use your hands in the area represented by the box in picture one.
Obviously if the ball goes inside the goal its a goal.
If the ball goes out of bounds and you only have one ball then the person who last got it must go get the ball and roll it to the other player kind like a pk but it is rolled to you.
If a player intentionally uses his or her hands do the same.
If its an accident then throw it to them like at their as hard as you can just up and a soft lob.
I suggest you play to between 10 and 20.
If you have a odd number of balls who ever hit the most out has to go get all the balls and if you have even number than who ever hits out the last ball goes and gets them.
2V2 or more-1 Player from each team is a goalie.
Besides that all the rules are the same.
Step 4: Play the Game
Play the game. It is a blast. If you want a little extra fun add a sprinkler under the trampoline.
