Introduction: Trenching Machine From a Burnt Angle Grinder
We have a house in the hills of Cordoba and sometimes we don't get there in three or four weeks. In this lapse of time the grass grows significantly,invading sidewalks and pavers
Using the gears box of a burnt angle grinder,a car window motor,a stick from a polisher I made a trencher to clean the borders of sidewalks and pavers from grass
Step 1: Dismantle the Angle Grinder
Disarm the grinder to expose the rotor split the winded body and get the axis ready to conect to a motor
Step 2: Put the Handle
I use and stick from a old polisher machine as the handle
Drill a hole on the lower extreme and fix the stick to the gear body of the angle grinder with the corresponding bolt
Step 3: Placing a Weel
With a piece of iron made a ball bearing support to handle it and better operate it
Step 4: Powering the Trencher
A 12 volt car electric window motor powers the device by means of a plastic tube
The motor is fixed to the handle with a self threading bolt,to the plastic side of the motor, and a plastic clamp
Step 5: Energising
The energy comes from a house alarm battery
To hold it I made a support from iron angle and a part of a bike inner tube
Step 6: Connecting
Find the propper switch mark the handle and drill a rectangular hole to insert the switch in the handle
Conect the battery to the motor by inserting the switch in between as in the picture
Step 7: The Trencher Blade
The trench will be made for a wood blade cutted in a way to form an spiral as seen on the picture
To give it more firmness,I weld a small iron in order to get both ends of the cutted blade,separeted
Step 8: Testing on the Field
The trencher works fairly good cleaning ,of invading grass ,the border of the sidewalk
As an unespected result,I found that it could be used for instaling hoses for artificial irrigation,underground cables,and so on. We'll just need a bigger blade and a bigger motor I guess,but that will be theme for another instructable
Hope you like and could be usefull for you, if so please vote me for the backyard and metal contests. Thanks .BR
