Tube Garden
Introduction: Tube Garden
Purpose-to inhibit broad leaf plants from obstructing light source for adjacent seed pods
Supplies:
flexible plastic
lettuce seeds
peat pellets
temperature gauge
hole punch
tape
LED grow light
Teacher Notes
Step 1: Set Up
On December 10th, 2019, I made an indoor greenhouse for this experiment. It consisted of lining a basement closet with plastic sheeting and installing an LED grow light.The house temperature was set at 70 degrees fahrenheit.
I put peat pellets into a styrofoam food tray and soaked them in water for 1 hour. I then inserted one lettuce seed into each pellet.
I set up 5 different experiments:
-no tubing (the control)
-tubing with a 1&1/4 inch diameter
-tubing with a 1&1/4 inch diameter with holes punched in sides
-tubing with a 1/2 inch diameter
-tubing with a 1/2 inch diameter with holes punched in sides
The tubing (plastic cylinders) was a recycled Christmas ornament lid. I found that the plastic was flexible and sturdy enough for this experiment. I cut out the plastic and then rolled it into a cylindrical tube and taped it with first aid tape. I used a hole puncher to create holes in one of the 1 & 1/4 inch tubes and holes in one of the 1/2 inch tubes. I pressed the tubes down into the peat pellet containing the lettuce seed.
Step 2: Continued Monitoring
I continued watering as the pellets dried out. The lighting was set on a timer to have 20 hours of light per day.
On 12/15/2019, there were signs of new growth in all of the experimental pellets. And on 12/28/2019, the seedlings are really starting to gain momentum.
Step 3: Results
On January 15th, I concluded the experiment. As you can see, the lettuce grown outside of the tubing has a span of 5 inches across thus inhibiting some of the other peat pellets from receiving light. As far as the lettuce in the tubing, we can measure a 4 inch height on the larger diameter tubes. The air holes did not make any difference as the lettuce growth was similar. The smaller diameter tubing (1/2 inch) did not allow for as much growth as the larger diameter tubing.
In conclusion, forcing the plants to grow in a more defined space can help alleviate the issues of broad leaf plants taking up valuable space.
Growing Beyond Earth Maker Contest
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Wearables Contest
      Wearables Contest
