Turn a Pumpkin Into Pumpkin Bread
About: Jack-of-all trades, master of some. I would probably be much more modest if it wasn't for these delusions of granduer that I suffer from.
Halloween is over.
The carved pumpkins have all gone mushy and been thrown out.
But you still have several pumpkins hanging around that were painted. What to do with them?
Time to get baking.
Teacher Notes
Step 1: Prepping the Pumpkin
In order to make use of the pumpkin, you will need to cook it to soften the flesh so it can be used.
Wash the pumpkin to remove any dirt / water based paints from the skin.
Cut the Pumpkin in half. I prefer to cut from top to bottom rather than side by side.
Scoop out the stringy innards and the seeds. You can save the seeds to roast in the oven, or use them to give the neighborhood squirrels a treat.
Trim off any soft sections of the pumpkin.
Line a cookie sheet with parchment paper.
Place the pumpkin halves cut side down on the cookie sheet.
Step 2: Cook Time
Now it is time to remove some of the excess moisture from the pumpkin and soften the flesh so it is easier to work with.
Bake in the oven for about an hour
350 degrees F / 177 degrees C / Gas Mark 4
You will notice your pumpkin has gotten a bit smaller and the skin has darkened.
Once you can easily separate the pumpkin flesh with a fork it is done.
If the edge of your pumpkin got a little crispy where it contacted the parchment paper feel free to trim those bits off.
Step 3: Scoop Out That Pumpkiny Goodness
If you have a commercially available pumpkin carving kit, the scoop that comes with the kit is awesome for getting the pumpkin flesh out of the skin. If not you can use a spoon.
Scrape as much of the flesh out of the skin as you can without tearing the skin. Nobody wants skin in their puree.
Step 4: Pumpkin Puree
Place the cooked pumpkin into a food processor and blend into a puree. The pumpkin will look "dry" when you first put it into the processor, but DO NOT add any liquid. The pumpkin will release liquid as it is pureed.
At this point you can either use the puree for a recipe or bag it up and store it in your freezer for future use.
This pumpkin was rather small and only yielded three cups of puree. The Larger pumpkin that I pureed earlier in the week yielded about 9 cups.
Step 5: Assembling the "Wet Ingredients"
In a medium mixing bowl combine:
Pumpkin Puree - 2 cups
Eggs - 4
Oil - 1 cup
Water - 2/3 cup
Sugar - 3 cups (I know this isn't technically a wet ingredient, but it dissolves into the liquid nicely)
mix together until blended completely
Step 6: Dry Ingredients
I like to put all of my dry ingredients through a sifter to avoid any lumps in the batter.
If you don't have a sifter, you can simply use a wire mesh strainer.
In a Large mixing bowl combine
All-Purpose Flour - 3 cups
Baking Soda - 2 teaspoons
Salt - 1 1/2 teaspoons
Pumpkin Pie Spice - 2 Teaspoons
Ground Clove - 1/2 Teaspoon
Mix together until blended
Step 7: Mixing Wet and Dry
Slowly stir the wet ingredient into the bowl of dry ingredients and mix until completely blended.
Step 8: Time to Start Loafin' Around
Grease three loaf pans
Pour an equal amount of batter into each of the pans. The pans will only be about half full, but that is OK because the mix will expand quite a bit as it bakes.
Step 9: Cooking
place the three loaf pans into a preheated oven
Bake for about 50 minutes.
Loaves are done once a toothpick / bamboo skewer / butter knife can be inserted into the middle of the loaf and it comes out clean
Halloween Contest 2018
Be the First to Share
    • Meal Prep Challenge
      Meal Prep Challenge
    • Reuse Contest
      Reuse Contest
    • Made with Math Contest
    4 Discussions
    kode1303
    12 months ago
    Very nice. I’ll try making this with my kids.
    Lorddrakekode1303
    Reply 12 months ago
    Awesome. It is always fun to share making with little minds :) have fun!!
    LorddrakePenolopy Bulnick
    Reply 12 months ago
    Thanks .. once it is approved for the Halloween contest,don't forget to vote :)
