Turn an Old SLR Lens Into a Telescope
25,247
116
22
Introduction: Turn an Old SLR Lens Into a Telescope
About: I've been taking things apart since I was 10. My mother wasn't impressed, even though I told her I knew how to put it back together... I've been making things since I picked up my first soldering iron (By Th...
Film is dead. At least that's what they tell us. I'll confess I haven't shot a picture with a film camera in years; digital has just gotten too convenient. I don't miss the hours - and expense - I used to spend in a darkroom getting the photo just right.
Still, I have a wonderful, full-manual, Minolta film SLR with several expensive lenses just gathering dust, and while, yes, I could adapt them to a modern digital SLR, I can't justify another camera right now.
There's not too much difference between a telephoto lens and a telescope; one focuses on film (Or a digital sensor), the other focuses on an eyepiece. I have a really nice 500mm Minolta mirror (catadioptric) lens that's very compact and was very expensive when I bought it new a couple of decades ago - I think it was during the Reagan administration... All the reviews say it's a super piece of optics, and it'd be a great shame to not put it to some use.
Why not turn it into a telescope?? (Or should that be Frankenscope?)
Step 1: With a Little Help From an A-dapter Kit...
There's an old song by Johnny Cash called "One piece at a Time," where the hero tries to assemble a car from parts snuck out of the factory over the course of several decades (Note: I don't condone stealing parts from your employer, but the song is funny!):
The transmission was a '53
And the motor turned out to be a '73
And when we tried to put in the bolts all the holes were gone.
So we drilled it out so that it would fit
And with a little bit of help from an A-daptor kit
We had that engine runnin' just like a song.
Somehow, I needed to adapt the eyepieces I had, with a smooth 1 1/4 inch barrel, to the bayonet mount of the Minolta lens. I don't think anybody has ever (commercially) made such an animal! My first try was laboriously concocted from an extra rear lens cap, a telescope focuser mount, and a lot of cutting, grinding, blood, profanity, and epoxy. It worked okay, but one issue you run into with camera lenses is focusing distance. I could focus the lens to infinity, but just barely, and I wanted to see if I could put an erecting prism on it as well as an eyepiece, so images would be right-side up. This would necessarily lengthen the optical path between the eyepiece and the lens rear element.
A camera lens is designed to use it's own focusing ring to focus on a specific plane - the plane of the film or sensor, usually only around an inch from the back of the lens. If the eyepiece is too far away from the rear of the lens, the lens will focus on very close objects, but cannot focus to infinity, making it pretty much useless as a telescope. The trick then becomes to get the front of the eyepiece as close to the rear of the lens as possible. I certainly didn't want to cut up any of my eyepieces to make them work on this project; I have other telescopes I want to use them on.
Fortunately, this particular lens, having a very large front aperture (which would make filters prohibitively expensive), has a provision for attaching filters to the back of the lens - in fact, it comes with a so-called "normal" filter already attached, ensuring that the optical path always has the same amount of glass in it. The lens is designed to have a filter there all the time.
Since I would be using the lens for a different purpose than designed, I decided to remove the "normal" filter (It just unscrews) and see if that gave me more room. With the filter removed, I could mount an un-modified eyepiece about a half inch closer to the the rear of the lens - In fact, the barrel of the eyepiece slid smoothly over the rearmost element of the lens without touching the glass.
Step 2: The '80s Meet the 21st Century
When this lens was made, around 35 years ago, technology available today didn't exist. Even optics have improved a great deal; you can get cameras with 20X - or even 40X - zoom lenses, making SLRs somewhat less desirable for anyone but a professional (or very serious amateur) photographer, since one of their main selling points is interchangeable lenses. But I digress. One thing that has recently become available is affordable 3D printing.
While hobby-grade 3D printing still leaves a lot to be desired in many ways, it is capable of making a lot of very useful things. Having recently bought a 3D printer, right now, to me, every problem I come across looks like it can be solved with... You guessed it, 3D printing!
While 3D printing isn't ideal for many things for a variety of reasons, it did work well for this project. I designed an adapter that would hold the front of the eyepiece right up against the lens, with a knurled thumbscrew to hold the eyepiece in. The adapter has an inner recess for a 4-40 T-nut (Metric would work fine, too, if that's what you've got), because I didn't have any small threaded inserts, which would have been preferable.
The T-nut is installed by positioning it and heating with a soldering iron or similar tool to seat it into the softened plastic. The knurled knob has a recess in the bottom for a nut, so a long screw can be threaded into the nut. The nut is held on the screw with a small dab of super glue, making the assembly permanent.
After printing, I test-fitted the adapter, and it fits quite well on the lens bayonet, while the eyepiece is a snug fit in the other end. I can now focus the lens to infinity with a lot of room left over. Success!
For those without a 3D printer, companies such as Shapeways will print something like this for around $10, and it will be better and stronger than something printed at home.
Sadly, the erecting mirror/prism did not work; it lengthened the optical path too much. But I still have a nice telescope as long as I'm okay with upside-down images.
Step 3: You Can't Handle This!
More precisely, You Can't Hold This in Your Hand and get very good results. The magnification of a telescope can be found by dividing the focal length of the scope (lens) by the focal length of the eyepiece. The lens is 500mm, the lowest power eyepiece I own is 25mm. 500/25=20 power at the lowest. 20X is right at the edge of what's feasible to hand-hold; the image just shakes too much to be very useful. If I was to use my 9mm eyepiece, the magnification would be over 50X, impossible to hand-hold in most cases.
So, before I'm done with this project, I need to find a way to mount this lens to a tripod.
Some of the Really Big monster lenses you see sports photographers using have tripod sockets on them, since the lens often weighs six times as much as the camera, besides being as long as a baseball bat! In that case, you're hanging the camera on the lens instead of the lens on the camera. No such luck here; the lens is only about 5 1/2 inches long and weighs about a pound and a half. To further complicate matters, only the knurled ring at the very back of the lens - intended as a grip for attaching to and detaching from the camera - is a fixed part of the lens. All the rest is a focusing ring, which has to turn freely. If I'm ever to mount a prism, or even a finder scope, on this, I must mount the lens by this rear ring only.
What's the easiest way to solidly mount a round thing? Fish a four-inch hose clamp out of the junk pile! It needed to be reshaped a bit so it could mount a round thing to a flat thing: the 3D printed mounting cradle.
I designed the cradle with notches for the hose clamp and a groove in the rear cradle to match the knurling on the lens. There is also a front cradle, which is not attached to the lens and is only there to take some of the weight off the lens and mount. The focusing ring rotates freely in this cradle.
The .stl file also has a recess for a 1/4"-20 nut that fits most camera tripods. A bit of super glue holds the nut in. After some massaging of the hose clamp into shape, everything fits and works very well.
While this project mounts a specific lens, the adapter can be used with most any Minolta bayonet mount lens and any 1 1/4" eyepiece. If you do this with a different lens, of course you're on your own as far as mounting is concerned.
I tried this adapter on my 75-205mm zoom lens, and while it worked on that also, a longer adapter would be advisable because the eyepiece barrel hits the rear element of the lens and could damage it.
This idea will work, with varying degrees of success, on just about any 35mm camera lens, as long as it can be manually focused. It's just a matter of adapting a rear lens cap for that brand of lens. Without a 3D printer, drilling a centered hole in a rear lens cap and finding an eyepiece mounting tube is really all that's necessary. The best part is none of this is irreversible, so the lens can still be used as intended!
Bring those orphaned lenses back to life!
Optics Contest
Second Prize in the
Optics Contest
Be the First to Share
    • Puzzles Speed Challenge
    • CNC Contest 2020
      CNC Contest 2020
    • Secret Compartment Challenge
    22 Discussions
    BigAndRed
    BigAndRed
    1 year ago
    Nice build to convert the lens.
    Still got film processing gear for my Bronica 645 camera but dont use it so much these days.
    I have several large lenses 400mm-1300mm that have the interchangeable T-mount that you just screw the appropriate adapter for your camera mount onto the thread, so it can be changed to Pentax or Sony or whatever you like. I'm still using my old 80's lenses on new modern digital camera bodies.
    Your Minolta lens will fit onto the Sony A-mount directly or the E-mount with a readily available adapter. This will enable you to continue using your old lenses.
    https://www.ebay.com.au/itm/Adapter-For-Sony-Minol...
    BPPhotog
    BPPhotog
    Reply 3 months ago
    "Your Minolta lens will fit onto the Sony A-mount directly or the E-mount with a readily available adapter."
    This is actually incorrect. His lens is the earlier Minolta SR mount introduced in 1958, denoted by the "ROKKOR" on it. They can be adapted to work on the Minolta AF/Sony Alpha mount, introduced in 1983, but only with an adapter that has corrective elements in it, not just something that changes the mount and flange distance. I had one of the fairly rare, Minolta-made adapters. Unfortunately it was quite disappointing, offering mediocre results at best.
    So unless you are shooting film with an SR body a handheld telescope is about the best use for this cool, old lens.
    CheerZ!
    BigAndRed
    BigAndRed
    Reply 3 months ago
    Ive got an old 500mm mirror lens like this with an adapter and Sony a6000 e-mount camera on it. No image stabiliser in lens so often a bit wonky. Im not a minolta expert so just working out what works.
    BPPhotog
    BPPhotog
    Reply 3 months ago
    The difference is that your true mirrorless camera has a very small flange distance so most any other mount can be adapted to it. The Maxxum Alpha mount is actually a bit longer than the previous Minolta mount thus requiring some converting elements.
    Yes, they also made a 500mm reflex for the Maxxum/Alpha mount, too; might also be the one you have.
    Get any good shots with it?
    BigAndRed
    BigAndRed
    Reply 3 months ago
    Baby honey eater sitting on birdbath in my front yard about 4m away. Bird is about 40-50mm high.
    Sony a6000, 500mm mirror lens, hand held, cropped to half frame, dehaze and sharpen used to clarify image. Not the sharpest lens but usable.
    gizmologist
    gizmologist
    Reply 1 year ago
    Right, I know that; I can't justify the purchase of the digital SLR body at present.
    BigAndRed
    BigAndRed
    Reply 1 year ago
    a second hand DSLR body probably cheaper than a 3D printer.
    gizmologist
    gizmologist
    Reply 1 year ago
    Difference is, it's my first 3D printer; it would be my 6th (or so) camera, and I wouldn't use it enough.
    ju1234
    ju1234
    1 year ago
    With my 300mm I tried it by just holding the 20mm eye piece behind it. It works. Perhaps the issue is going to be the light gathering capability and available magnification. Even the longest lens is not going to match the diameter of front element to a telescope.
    BillS275
    BillS275
    Question 1 year ago on Step 3
    do you sell the kit i have an older pantex with a number of lenses ...bill
    gizmologist
    gizmologist
    Answer 1 year ago
    I could sell you the Minolta-to-eyepiece adapter; I don't know if it would fit a Pantex. Or you could download the "cap Adapter" above, and have a place like Shapeways print it.
    studleylee
    studleylee
    1 year ago
    A 45 degree mirror attachment on the big lens would invert the image. Will look like one of those cameras you look down into.
    gizmologist
    gizmologist
    Reply 1 year ago
    It would erect the image. The image is already inverted.
    studleylee
    studleylee
    Reply 1 year ago
    Right, I thought you want non-inversion overall. My error. :-)
    SHOE0007
    SHOE0007
    1 year ago
    Sounds like a really cool idea. Really like it too.
    Phoghat
    Phoghat
    1 year ago
    " I haven't shot a picture with a film camera in years" and yet there's a big resurgence in film photography. Not to take away from your project, which IS nicely done, but an awful lot of people are getting back into film
    JamesmMcArdle
    JamesmMcArdle
    1 year ago
    Brilliant idea! I imagine that camera optics are way superior to that of most cheap telescopes and should be 'faster', letting in more light in the case of your 500mm. I am wondering though why one couldn't use the camera as the reflex mirror and with the prism and focussing screen removed (as I can do on my 1959 Nikon F body), and attach the eyepiece there...a jury-rig worked fine with a 1000mm lens and 20mm eyepiece for me. Certainly makes a bright and vivid telescope...thank you!
    revanwhitto
    revanwhitto
    I seem to remember that back in the day of film and in other fields that still use scopes of some sort, That there was a right angle adapter that could be made to hold your prism and whatever you needed to turn your image right side up could be put in an item similar to the right angle lens hol;der and this might solve the problem.
    DennisO22
    DennisO22
    1 year ago
    Film is not dead - not by a long way. I still shoot and process black and white film. Film negative images outlast digital by years! How long do your images last when you burn them onto a CD - 5 years? I have film negatives that are at least 30 years old and what about the negatives dating from the 2nd world war and still capable of producing a hard copy. They can be scanned and used to produce a digital print. That's my moan over. I like the idea of re-purposing kit to give it a new lease of life. Great idea SLR lens to telescope conversion. By the way. I believe they are starting to produce colour slide film again due to demand from professional photographers.
    TimothyP14
    TimothyP14
    1 year ago
    Dig the shoutout to Johnny Cash in step 1
