Turn an Ordinary USB Stick Into a Secure USB Stick
About: I analyze data and provide reporting informing the firm’s practice, about data such as project profitability and Revit model performance. Recently, I have started to dive into environmental sensors that rep...
In this Instructable we will learn how to turn an ordinary USB stick into a secure USB stick. All with standard Windows 10 features, nothing special and nothing extra to purchase.
What you need:
  • A USB Thumb drive or stick. I highly recommend getting a new drive for this.
  • Windows 10 Pro*
* Notes:
  • You only need Windows 10 Professional to encrypt the drive.
  • You can any version of Windows 10 to use the drive. (Home or Pro)
Teacher Notes
Step 1: Walk Though
This great video will take you through all the steps.
If you like to read and follow steps, then scroll down.
Step 2: Insert the Thumb Drive in to the Computer
Insert the thumb drive into your computer.
A. Grasp your USB Thumb Drive with the correct hand or foot.
B. Insert the drive silver side in, if it doesn't go in rotate it and try again.
Note: You may need to rotate the drive up to 3 times.
C. Let go.
Step 3: Encrypt Your Drive.
Once your drive in recognized it will appear in the Windows File Explorer.
A. Right click on the drive and pick Turn on BitLocker.
Note: Windows 10 Pro is required for this step. Windows 10 Home will work fine after encrypting the drive.
Step 4: BitLocker Wizard.
Once the Wizard pops up you will be guided through the steps to encrypt your drive.
A. Think of a password you will remember and will be easy to type. Then write it down or better yet put it in your password manager.
B. Choose to Print or Save your Recovery Key. The recovery key is used if you forget your password. Lose both and you are S.O.L.
C. Choose how much of the drive to encrypt. New drive = Used space only, Existing Drive = Entire Drive
D. Choose Mode. If this is a USB drive then choose Compatible mode.
E. Pick Start
F. Wait
G. Pick Closed.
Step 5: How to Unlock Your Drive.
A. Remove your drive from your computer
B. Insert the drive as you did in the previous step.
C. After you insert the drive you will see a notification at the lower left of the screen, Click on that.
D. Windows will now ask you for your password, it's at the upper left of the screen, then pick unlock.
Windows will then unlock your drive and you can use it.
Step 6: BitLocker Achievement Unlocked!
Here is your achievement patch. Print it out and hang it on your wall.
Safe and Secure Challenge
    • Indoor Lighting Contest
    • Make It Fly Challenge
    • Growing Beyond Earth Maker Contest
    3 Discussions
    BIMThoughts
    Tip 6 months ago
    If you partition your USB disk in to two or more different drive letters, then you can do this to one of the partitions. Then you would have the Hanna Montana of USB disks, the best of both worlds. One part secure the other open to the world.
    BIMThoughts
    6 months ago
    If the partition shows up as a different drive letter it will work. I just tried it out to make sure.
    k8e
    6 months ago on Step 5
    - Can you lock only -part/partition/segment- of the drive?
