Turtle Shell From Coconut
4,306
77
11
Introduction: Turtle Shell From Coconut
About: I like to make small things and if I see something I like I might try to make my own version... with different results :)
Coconut shell is a great material to make small pendants out of, ass they can look great rough, slightly sanded or polished. As the shell is pretty hard, but relatively easy to work, and something most people have access to is an ideal material for anyone with the interest for small wood like project.
In this example I will show you how to make a turtle shell pendant out off a coconut shell, but it could be anything you want, you just have to remember that the shell has a curve to it.
Tools used:
Dremel with a round cutting bit
Wood Burning Pen
Belt sander (or grid 80 sandpaper)
Bandsaw (or any saw at hand)
Pencil
Marker
Material used:
Coconut shell
Leather cord
Step 1: Shape of the Shell
First you have to decide om a shape/design for your pendant.
I wanted to make a turtle shell, but as my memory isn’t the best so I searched the internet for turtle shell patterns to get some inspiration and drew the basic shape directly on the coconut, with a marker, to make it easier to see.
If you don’t trust your own drawing skills or want to make it symmetric you could try drawing your design on some graph paper. Just keep drawing the shape till you like it. When you have the perfect design to your liking you can copy it to baking paper and then transfer it to the shell.
Step 2: Cut the Shell
Try cutting as close to the drawn shape as possible just stay outside the line. It should be relatively simple to cut as the shell is thin and strong.
Step 3: Sand the Shell
It is easy using the belt sander to sand away the edge till the outer shape are reached, then lightly sand the rough outer surface to get a look you like. Then give it a bevel around the edge to make it smooth and nice to the touch.
Step 4: Form the Shell
Now it is time to draw where the details, with a pencil, are goner be and take the Dremel and engrave the details into the surface to give it a slight 3d effect.
Engraving can be a bit tricky because the shell has different hardness/density’s, I found it easier to control where the cut goes, by pinning the shell to the table and engraving with firm and direct cuts/movements.
Remember to drill an opening for the cord… I forgot and had to make it afterwards.
Step 5: Burn the Shell
First and foremost, do this step at a ventilated area or preferably outside, as the smoke can be lingering and unhealth.
Now it is just to burn along the engraving and the hard part are done. As the shell have different hardness/density it will be easier to burn some areas then others so it is important to burn with a light hand so as to not accidentally make unwanted deep burn marks.
Step 6: Enjoy the Shell ;)
Now, just put in the cord and enjoy the turtle shell.
This was my first try and roughly took 2-3 hours to make, hope you enjoyed it :)
Jewelry Challenge
Jewelry Challenge
1 Person Made This Project!
  • Recycled Speed Challenge
  • Make it Move Contest 2020
  • Build a Tool Contest
11 Discussions
storytellers14324
storytellers14324
1 year ago
I'd love to try it but the only problem is the burning part :v i don't have anything like that, neither any substitut. :(
JC the hobbyist
JC the hobbyist
Reply 1 year ago
That is a
shame, you could try with a thin black or very dark brown marker.
It will not
give the same reflection as a burning, but just by outlining the borders it will
make a great visual effect… and you would avoid the burning smell :)
winneremerald12
winneremerald12
Question 1 year ago
What did you burn the shell with?
JC the hobbyist
JC the hobbyist
Answer 1 year ago
I used a woodburning
pen with a thin round tip.
winneremerald12
winneremerald12
Reply 1 year ago
Thanks! Where can I find one of those?
JC the hobbyist
JC the hobbyist
Reply 1 year ago
They should be pretty easy to find on eBay, Amazon or other places that deal with hobby articles
seamster
seamster
1 year ago
Very nice! I made a lot of stuff out of coconut shells when I was younger. It's a lot of fun! : )
abuhafss
abuhafss
Reply 1 year ago
Hi
Would you please name some of them so that I can get ideas what else could be made from the shell.
Thanks
seamster
seamster
Reply 1 year ago
I made a lot of bowls and cups, a coconut bikini, and even a mini potato cannon that shot nerf darts and little potato chunks . . not recommended! : )
Penolopy Bulnick
Penolopy Bulnick
1 year ago
This looks great! That's the perfect material for a turtle shell :)
TeddiB
TeddiB
1 year ago
I love it! My mind is jumping from idea to idea with the coconut shell! Thank you so much for sharing.
