Magnetic Switch Door Alarm Sensor, Normally Open, Simple Project, 100% Working, Source Code Given
Introduction: Magnetic Switch Door Alarm Sensor, Normally Open, Simple Project, 100% Working, Source Code Given
Description:
Hi guys, I'm going to make tutorial about MC-18 Magnetic Switch Sensor Alarm that operates in normally open mode.
  • Switch Type: NO(normal Close type), the circuit is Open normally, and, circuit is connected when magnet is near.
  • The reed switch is an electrical switch operated by an applied magnetic field.
  • Designed for use with alarm systems. Great for use in family and factory window, door. etc
Specification:
  • Product Name : Door Magnetic Switch
  • Switch Type : NO (Normally Open)
  • Contact Capacity : 0.5A(Maximum Switch Current)
  • Switch Voltage : 100V
  • Rated Power : 10W
  • Breakdown Volt : DC 200V
  • Operating Distance : 15-25mm
  • Cable Length : 20cm/7.9"
  • Each Size(Approx) : 23 x 14 x 7mm /0.9" x 0.55" x 0.28"(L*W*H)
  • Color : White
  • Housing Material : ABS
  • Weight : 7g
  • Package Content :1 Pair x Door Magnetic Switch
Teacher Notes
Step 1: Material Preparation
Step 2: Follow the Video
Step 3: Source Code
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
