Tutorial: How to Make a Simple Temperature Sensor by Using DS18B20 and Arduino UNO
Introduction: Tutorial: How to Make a Simple Temperature Sensor by Using DS18B20 and Arduino UNO
Description:
This tutorial will show you a few simple steps on how to make temperature sensor functional. It just take a few minutes to make it true on your project. Goodluck !
The DS18B20 digital thermometer provides 9-bit to 12-bit Celsius temperature measurements and has an alarm function with nonvolatile user-programmable upper and lower trigger points. The DS18B20 communicates over a 1-Wire bus that by definition requires only one data line (and ground) for communication with a central microprocessor. In addition, the DS18B20 can derive power directly from the data line (“parasite power”), eliminating the need for an external power supply.
Details:
  • DS18B20 Temperature Sensor Single Bus Digital Temperature Sensor Module For Arduino Diy KitFeatures:Made of Environmentally friendly materials material, durable
  • Exquisite workmanship.
  • Mini size, easy to carry.
  • Precision continuous self-calibrating analog/digital.
  • Greatly reduces current consumption during idle periods.
  • Typical applications include portable instrumentation industrial process control and small transmitters.
Specifications:
  • Material: Electronic component
  • Color: Black
  • SIZE: 12X20mm
  • Package Included:1 x Temperature Sensor Detection Module
Teacher Notes
Step 1: Step 1: Material Preparation
All the material or component that we have use in this tutorial you guys can get all of them at link below:
DS18B20 TEMPERATURE SENSOR MODULE
Arduino UNO
Mini Breadboard
Jumper Wires
Step 2: Step 2: Follow the Instruction in This Video
Step 3: Step 3: Source Code
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
