Introduction: Tweet Pumpkin - Change LED Color Via Twitter With Raspberry Pi - IoT
The main purpose of this Instructable is to learn how to use Twitter's API to pull tweets into your python code, so that you can use real time data in your projects
After this Tutorial, you will be familiar with:
Raspberry Pi Blink LED
Twitter's Apps and Twitter APIs structure
JSON
oAuth
I hope this will help you improve your existing project or spark a new idea for a future project
Step 1: Carve the Pumpkin.
Get yourself a nice pumpkin a week before Halloween
Find a Halloween pumpkin cool template to carve
I chose the traditional Jack-O-Lantern for this project
http://www.freefunhalloween.com/pumpkin-stencils/j...
Carve the Pumpkin using the template. Be careful not to cut yourself in the process
Keep your pumpkin in a cool place, with no direct sunlight. This will help preserve your pumpkin
Step 2: Set Up the Hardware
For this project, I am using all the components that come in the a Raspberry Pi B+ Ultimate CanaKit . You can purchase it here (http://www.amazon.com/CanaKit-Raspberry-Ultimate-Starter-Components/dp/B00G1PNG54)
In order to have a standalone pumpkin, I am using aUSB wireless adapter for internet connection and portable battery to power the Hardware. I have left the Raspberry Pi running off this 13000mAh power bank and it stayed on for over 16 hours with the LEDs Blinking.
Setup the wireless network in you raspberry pi (https://www.youtube.com/watch?v=_1WWKUM_IUA)
Install TightVNC Server on raspberry pi and VNC Viewer on your desktop for Remote Login (https://www.youtube.com/watch?v=tbbp-vvsKZ4)
IMPORTANT: Do one of those Raspberry Pi Blink LED tutorials. Here is a quick one I found via google http://www.rpiblog.com/2012/09/using-gpio-of-raspberry-pi-to-blink-led.html. This is the "Hello World" of hardware and will give you enough confidence to move on.
If it is the first time your Pi is online, make sure to run update and upgrade on brand new raspberry pi. If you don't know what this means then look for one of those "setting up new raspberry pi" videos on youtube
-=THE HARDWARE LIST=-
RaspberryPy B+
USB Wireless Adapter
Breadboard
LEDs
Some resistors
13000 mAh 5V power bank
Step 3: Set Up the Twitter API
FACT: The Twitter API had a major update and now it requires authentication to use and it has been broken down into a few smaller APIs for different purposes. For this project, we will be using Twitter's REST API
To authenticate to Twitter's API you need a Token and a Key that are generated when you create a Twitter Application
To get a Twitter Application, you need twitter account WITH A VERIFIED PHONE NUMBER.
Create a new Twitter app at https://apps.twitter.com/. The info entered for Name, Description, and Website of this app doesn't really affect our python code because all we need is the Token and Key, so type in anything you want.
Once the app is created, go into it's "Key and Access Token" Tab and click to generate a new Key and Token
Take note of your CUSTOMER_KEY, CUSTOMER_SECRETE, ACCESS_KEY, ACCESS_SECRETE
Step 4: Set Up the Python
In this step, we will retrieve a simple tweet from your twitter timeline via python
Twitter API returns data in JSON format. Python as a Library called simplejson that handles JSON as dictionaries.
Twitter API authenticates via oAuth. Python has a library called httplib2 that has oAuth inside of it.
To get started, Install Python 2.7 if you do not have it already in your rapsberry
Install the simplejson and httplinb packages. Hint: I used PIP to easily install python packages.
Create a new python script and copy the code .Make sure you change the 5 different places in the code that are IN UPPERCASE with your own information
import simplejson as jsonimport oauth2 as oauth
CONSUMER_KEY = "YOUR CONSUMER_KEY"
CONSUMER_SECRET = "YOURCONSUMER_SECRET"
ACCESS_KEY = "YOURACCESS_KEY"
ACCESS_SECRET = "YOURACCESS_SECRET"
consumer = oauth.Consumer(key=CONSUMER_KEY, secret=CONSUMER_SECRET)
access_token = oauth.Token(key=ACCESS_KEY, secret=ACCESS_SECRET)
client = oauth.Client(consumer, access_token)
timeline_endpoint = "https://api.twitter.com/1.1/statuses/user_timeline.json?sreen_name=YOUR_SCREENAME&count=2"
response, data = client.request(timeline_endpoint)
tweets = json.loads(data)
for tweet in tweets:
print tweet['text']
Step 5: The Final Software
Now that everything is setup properly, here is the final code
import RPi.GPIO as GPIO
from time import sleep
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
#Here enter your GPIO number for each color
RED = 18
GREEN = 19
YELLOW = 17
BLUE = 16
def main():
tweet_text = get_new_tweet()
new_color, BLINK_FLAG = color_from_tweet(tweet_text)
if new_color:
if BLINK_FLAG:
blink(new_color, 999)
else:
change_color(new_color)
else:
print "No new color"
def get_new_tweet():
timeline_endpoint = "https://api.twitter.com/1.1/statuses/mentions_timeline.json?count=1"
print tweet['text']
return tweet['text']
def color_from_tweet(tweet):
if "BLINK" in tweet:
BLINK_FLAG = True
else:
BLINK_FLAG = False
if "RED" in tweet:
return RED, BLINK_FLAG
if "GREEN" in tweet:
return GREEN, BLINK_FLAG
if "YELLOW" in tweet:
return YELLOW, BLINK_FLAG
if "BLUE" in tweet:
return BLUE, BLINK_FLAG
return None, None
def change_color(color):
off()
GPIO.setup(color, GPIO.OUT)
GPIO.output(color,True)
def off():
for colors in [RED,GREEN,YELLOW,BLUE]:
GPIO.setup(colors, GPIO.OUT)
GPIO.output(colors,False)
def blink(color, time):
GPIO.output(color, False)
for x in range(time):
sleep(.5)
GPIO.output(color,False)
sleep(.5)
print ".",
print ""
