Twin Tower Shelf
1,013
26
30
Introduction: Twin Tower Shelf
This shelf is for storing all sorts of things. There are twin towers and some slots at the bottom. You can hang it or not. WARNING this thing may be over 100 pounds!
Supplies:
26 total feet 8/4 x 12 inch red oak wood cut as follows:
2 x 48 inches
2 x 32.5 inches
6 x 8.5 inches
1 x 20.5 inches
2 x 24 inches
1 x 22.75 inches
wood glue
drill
a lot of wood screws
a large square (its a ruler shaped as an L)
a small square (with level and measuring edge)
a sander + sand paper (180 grit for the beginning and 60 grit for the end)
Teacher Notes
Step 1: Preparation and Layout
Lay out a mock-up of the shelf on the floor.
Step 2: Assembly
Get the first 48 incher and the 32.5 incher (the base) and align base with right side with the large Square .
Then drill 3 holes to accommodate the wood screws that will connect the pieces.
Apply glue to the end of each piece.
Then screw the pieces together with drill.
Step 3: Assembly (cont.)
Get the other 48 inch vertical piece and align it with a Square on the other side of the 32.5 inch bottom shelf
Apply glue on the ends of the boards and connect them.
Drill three holes as before, and then screw the pieces together with the drill.
Step 4: Assembly (cont.)
Next, you will need the other 32.5 incher.
Align it 24 inches above the other 32.5 inch base shelf.
Drill 3 holes from the sides for the wood screws on each side.
Screw the piece in place.
Step 5: Assembly (cont.)
Get the two 24 inchers and put them each 9.25 inches away from 48 incher on each side of the shelf and on top of the 32.5 incher. Then drill three holes through the 32.5 incher into the bottom of the 24 incher and drill in 3 screws to hold the vertical pieces in place, as shown in the picture.
Step 6: Assembly (cont.)
Next, you need to get the four 12 inchers. Place two of them in between the two columns at the top, then drill three holes from the right and left with the drill, then put in three screws on each side with the drill. For the center tower shelves, drill from the two sides 3 holes and drill in 3 screws for each tower as shown.
Step 7: Assembly (cont.)
Now you will need to connect the vertical partition (20.5 incher) with the horizontal shelf (the 22.75 incher). Drill 3 holes without the other piece under it, then drill 3 screws with the tips only showing and the other piece not under it. Then mark the other board by putting the board under it then drill the holes where the marks are. Then you will need to drill in 3 screws so they are connected.
Step 8: Assembly (cont.)
Then you will need to install the vertical partition with horizonal shelf in the section below the towers using 6 screws drilled in from the bottom and the sides.
Step 9: Final Sanding
You will need 60 grit sand paper and if you have any wood planks that are not in place correctly you could sand it down with the 60 grit sand paper. Then you should get a wet sponge and wipe off all the dust.
Step 10: Enjoy Your Creation!
And there you go. That is it. I hope you like the creation!
Shelving Contest
Shelving Contest
Be the First to Share
    • Cardboard Speed Challenge
    • Sculpting Challenge
      Sculpting Challenge
    • 3D Printed Contest
      3D Printed Contest
    30 Discussions
    jfbabinecz
    jfbabinecz
    2 months ago
    This is a very professional and tasteful design. Im extremely impressed with your talents.
    cdistel
    cdistel
    2 months ago on Step 10
    Wow! Amazing design and such great craftmanship! Very impressive!
    bwmcshane
    bwmcshane
    2 months ago
    Mike, congratulations on your twin tower project. You did a fabulous job putting it together. And I can see that the shelves have many uses. 🙂
    michael.ettinger
    michael.ettinger
    Wow you made that! If I tried to make it I would just ruin the piece’s. Please teach me how to make that I will do anything. Promise
    - michael
    tiffany_vaccari
    tiffany_vaccari
    2 months ago
    I'm so proud of you Mike! Your creativity and innovativeness make you such a shining star!
    bobby4
    bobby4
    2 months ago
    WOW!! This shelf is great! It must’ve been super hard to construct such a cool looking piece, whoever built it deserves to WIN!
    JackDW
    JackDW
    2 months ago
    Excellent. Great job!!!
    dnbonner
    dnbonner
    2 months ago
    This is well crafted. Nice job
    kimbabinecz
    kimbabinecz
    2 months ago
    Wow! I'm beyond impressed!!
    brooktrout69
    brooktrout69
    2 months ago on Introduction
    Wonderful design! Beautiful selection of building materials, especially the use of hardwood... The Twin Tower shelf will grace any room ;-) Like the nice easy build factor and instructions. It's a WINNER!
    KristenK43
    KristenK43
    2 months ago
    Great job! :)
