Introduction: Twinkling Christmas Tree Card
This project was created for YuKonstruct's Chibitronics Build Night and uses a Chibitronics effects sticker and three LED stickers.
The effect sticker has three pads: + and – for power and a signal pad that generates the pattern. The signal pad is pre-programmed to switch between + and -, which causes the lights connected to it to turn on and off.
YuKonstruct is the first makerspace in Canada's north. Our mission is to provide access to shared space, quality tools, available expertise, and a collaborative environment to help makers build anything!
For this card you'll need:
- 3 Chibitronics LED stickers
- Chibitronics twinkle effects sticker
- Copper tape
- Coin cell battery
- Cardstock in blue, green and white
- Craft foam
- Bobby pin or paper clip
- Scissors
- Glue
- Stickers or other embellishments (optional)
Step 1: Make the Circuit
Fold a piece of blue cardstock in half to make a card.
Using the circuit diagram as a guide, apply the copper tape and Chibitronics stickers to the front of the card. For the best results, fold copper tape to avoid tearing around corners.
Test to make sure the circuit works by placing a bit of copper tape over the + side of the battery and copper spiral before proceeding to the next steps.
Step 2: Add Tree and Snow
Glue the battery in place. Be careful to ensure it maintains contact with the copper tape.
Cut a Christmas tree out of green cardstock. Punch holes in the tree over the LEDs. Glue the tree to the front of the card with small craft foam pieces to keep it raised over the LEDs.
Cut a strip of cardstock the width of the card to be the ground below your Christmas tree. Apply a thick strip of copper tape to the back. Glue the edges of the ground piece to the front of the card.
Step 3: Decorate
Pinch together the ground strip and card front with a bobby pin or paper clip. The card can be turned on and off by sliding the clip back and forth.
Decorate the card as desired.
Papercraft Contest
Make it Glow!
