We have currently built two standalone USB powered DIY projects and we will continue to build more. Powering all of them is going to be a challenge and thus, I decided to build this USB power hub that can be used to power passive devices. You can also use the split, microUSB cables to connect up to 8 devices in total. The hub has a wide input voltage range and is small enough to be tucked away beneath your desk.
NOTE: This will NOT be able to charge smartphones or other "smart" devices as there is no USB power negotiation capability. This is meant to be used with "dumb" devices that simply need 5V power like most DIY electronic projects.
Teacher Notes
Step 1: Watch the Video
This is a very simple DIY build but the video above talks about the choice of the voltage regulator (linear vs switching) used for this project and it also goes over the enclosure details. I'd recommend watching it to get a better understanding of how it all comes together.
Step 2: Gather the Electronics
We need the following electronics to build this project:
- 1x LM2596 DC-DC power module
- 4x USB Type A breakout boards
- 1x DC power connector
- 1x DC power adaptor - 9V or above
These are commonly available online and here are some reference links to help you get started:
- LM2596 Module: https://www.ebay.co.uk/itm/LM2596-DC-DC-Adjustable...
- USB Breakout Boards: https://www.ebay.co.uk/itm/10Pcs-USB-Type-A-Female...
- DC Power Connector: https://www.ebay.co.uk/itm/4x-5-5mm-x-2-1mm-PCB-DC...
Step 3: Connect and Adjust the Output Voltage
We start by wiring the DC connector to the input of the LM2596 module. Keep a note of the polarity and then connect the power adaptor. The blue light should start glowing. Use a screwdriver to adjust the trim-pot and set the voltage to 5V.
Step 4: Decide on the Enclosure
We then need to wire the USB breakout boards to the power module but before we do this, decide on the enclosure so that you can use the correct wire lengths. I designed a custom enclosure that holds all the electronics in a tight space, which is what I was going for.
Here's the link to the model:
Step 5: Complete the Wiring & Test
Then, wire up all the USB boards with the correct wire lengths. Then, power on the module and make sure you have 5V across all the USB ports with the correct polarity.
Step 6: Add the Electronics to the Enclosure & Seal
The next step is to add the electronics to the enclosure and seal it. I used hot glue to hold all the electronics in position. I then used the top half to close it. The enclosure should fit snugly as it has a lip and groove feature, if not, you can also apply some glue before closing it.
Step 7: Use It & Share
This is a handy power hub that I will be using frequently. I've added the approximate cost breakdown in case you need it. You can also add the split USB cables as seen above to power a total of 8 USB devices.
Don't forget to follow us on social media to get notified of future builds. Here are some links:
- YouTube: https://www.youtube.com/channel/UCbWiK1A5RqAugSquB...
- BnBe Website: https://www.bitsnblobs.com/
- Instagram: https://www.instagram.com/bnbe.club/
- Facebook: https://www.facebook.com/BnBe.club
- Twitter: https://twitter.com/bnbe_club
14 Discussions
22 days ago
Good job mate
Reply 22 days ago
Thank you!
22 days ago
Suitable for USB power up, but not charging smartphones. Without using data signals (https://www.maximintegrated.com/en/design/technical-documents/tutorials/5/5801.html) the USB will charge the smartphone with current max 500mA, even source would be able provide over 2A.
Reply 22 days ago
Yes! This is NOT meant to charge smartphones as mentioned in the video. I designed this to power USB DIY devices as there's no point buying special power hubs for those.
22 days ago
BRAVO !!! BRAVO !!!BRAVO !!!
your detail+simple explanation is extremely good for the beginner e.engineer so
danke danke danke... my question is NOT on the lm2596, but do you know of any that will provide similar function for devices require 24v 14a( consistent ) ??? have a great day !!!
Reply 22 days ago
Thank you. For that rating, you will have to use bigger power supplies, I did a quick search and found the following:
https://uk.rs-online.com/web/p/non-isolated-dc-dc-...
https://www.meanwelldirect.co.uk/products/300w-sin...
Hope this helps.
Reply 22 days ago
as a fav. to me to all those starters, PLEASE DO NOT STOP bravo !!! brao !!! bravo !!!
Reply 22 days ago
Thank you! I will try my best :) Have a great day!
Question 22 days ago on Step 7
Is there a reason these hubs are typically limited to 4 ports?
Answer 22 days ago
This is a custom device so you can add more ports if you like. I was happy with 4 ports because that keeps it a little compact and I can use the split USB cables to connect more devices. For commercialy available USB hubs, the number of ports will be limited by the USB hub controller but we do not use one here. I'm guessing it's a tradeoff between price and number of ports. Hope this helps.
22 days ago
You daisy chained each usb onto the next, would it make any different if you wired each usb directly to the lm2596 buck instead?
Reply 22 days ago
It would be better to wire the USB ports directly to the LM2596 as that way, you can use thinner wire and still draw high current. I mainly daisy chained them to make it a bit neat and I wouldn't be drawing close to the 3A rating.
22 days ago
How much power can this simple circuit deliver to each port, and is that in any way protecting the devices plugged in? I'd really like to power a handful of raspberry pi devices without so many wall warts :)
Reply 22 days ago
The LM2596 is rated for a max current draw of 3A. If you use a suitable DC power adaptor (9V or higher, 3A or higher) then you will be able to supply 3A in total. I'd recommend wiring all the ports in parallel, directly to the LM2596 if you intend drawing that much current. There's no individual limit on the ports themselves, so you can use either one.
Higher output current: check out the XL4015 module that can deliver a max current of 5A and is simple to use.
Protection: You can add a diode for reverse polarity protection and a bit of isolation. A polyfuse can be used to deal with any short circuits. Hope this helps :)
