USB Power Hack, Adding Usb Ports to a DX052 Mixer
18,667
23
6
This is another usb power hack. It demonstrates how to attach a couple usb ports on a DX052 mixer board for powering your ipod(s) or any USB device. I bought this mixer recently and love using it.
Step 1: Equipment
The following equipment can be bought at just about any radioshack or electronics store.
Electronics:
  • Soldering Iron
  • 2 10K resistors
  • LM7805 +5V voltage regulator
Other equipment:
  • 2 port USB connector with pci bracket (taken from a computer case)
  • drill and bits that can cut through metal
  • rotozip
Step 2: Take Apart the DX052 and Tap Power Supply
The DX052 comes apart very easily, unscrew the top and disconnect all cables. The cables that connect the mixing controls to the power supply are socket connections.
With a multi-meter find a connection near the power supply to pull DC voltage. The one I used was 16v. Carefully solder a wire to it to feed the voltage regulator.
Step 3: Create the 5v Circuit to Supply the USB Connector
You may want to lay this out on a breadboard first. Make sure you connect the pins to the LM7805 in the right order.
The pull up resisters for D- are required for some ipods charge but aren't needed for most usb devices.
Step 4: Place the Circuit in the DX052 Mixer
There is plenty of room. I conveniently mounted the LM7804 on the ground tap.
Strip the USB connector and solder GND, 5v, D- and D+ to it
Step 5: Drill Holes in the DX052 for the Usb Connections
With a drill bit that can cut through metal make holes for the usb screws and connections, fill them out with a rotozip or dremel.
Cut the PC USB PCI slot bracket on both ends.
Step 6: Putting the Mixer Back Together
Attach the USB bracket and connect the USB ports.
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    6 Discussions
    klaviatury
    7 years ago on Introduction
    Its cute and all, seems like a bad placement for the ports tho. Nice to see new life to these old devices, I can remember when DJs actually did work for a living now anyone is a DJ with Virtual DJ applications.
    brndmg
    12 years ago
    Thats a great idea. How would you control the amperage in such a circuit. I am looking to power my ancient digital camera (epson photopc 800) with a 3.5 V/ 2.5 A usb adaptor, but I don't know how to drop the voltage from the usb 5 V to 2.5 V and increase the amperage from 500mA to 2.5A.
    jarv34brndmg
    Reply 12 years ago
    What you probably want to read about are DC to DC converters
    http://en.wikipedia.org/wiki/DC_to_DC_converter
    Assuming you are doing this from a computer's usb port typically it can only supply about 100mA I.. unfortunately you will not be able to draw 2.5A without an external source. Your best bet is to tap into your computers power supply directly although this may defeat the purpose of what you were trying to do.
    brndmgjarv34
    Reply 12 years ago
    Thanks for the help jarv.
    westfw
    12 years ago
    Nice idea. There have been lots of hacks using power from a computer's USB ports but this is the first I've seen to add (power-only) USB ports to another device for the purpose of providing power...
    Myselfwestfw
    Reply 12 years ago
    I guess adding a lighter socket to a rechargeable 12-volt spotlight doesn't qualify, does it? ;) I tellya what though, walking through town with a CB radio in my backpack was a lot of fun, at age 15 or so....
