UV Exposure Box From Table Top Scanner
Introduction: UV Exposure Box From Table Top Scanner
About: Always liked to make 'things'....
Making PCB's at home with photosensitive film at home, requires UV exposure box, and I've decided to make one - quickly, from the table top scanner I've received for free,that was on its way to the trash - decided to give it a second life :)
Supplies:
UV Led strip
Old tabletop scanner
Plexi or acrylic sheet
Soldering iron (solder and soldering flux)
Power socket
Assorted wires
Teacher Notes
Step 1: Cleanup and Dissassembly
First step - cleanup, and gutting it the all electronic and mechanical components out of the scanner - we need only "box".
Step 2: Mounting LED Base
Bottom of the scanner was not really designed for the purpose i'm going to use it, so I opted to use a clear Plexi sheet I had purchased for other project, (3mm thick)
Easy to cut - just score it and break off. I have used pieces of it to make a "feet" for the LED base - super glue is perfect for this.
Step 3: Design LED Layout
For LED strips I've marked spacing on the sheets (there is still protective foil on the surface) and later I've scored lines on the foil with the hobby knife. This way after removing protecting film place for LED strips will be clearly visible.
Step 4: LED Soldering
Very straight forward, cut LED strip to a size (there is cut mark every 3 LED's), Daisy chain by soldering them, positive to positive, negative to negative, and one of the ends to the power socket.
Step 5: Test Your Circiut
Make sure polarity of your power supply, matches polarity on the power socket. Put it together and voila. Done.
Please note, that it is incredibly easy circuit. You can upgrade it with a switch, with a timer unit etc...
Have fun!
Reuse Contest
Reuse Contest
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    audreyobscura
    audreyobscura
    21 days ago
    This is a really clever upcycle!
