UV Light 3D Fluorescent
About: im Hessam. im work with Unity3D and 3d Modeling with Cinema 4D and 3d priner . i love Technology and Electronic.
Teacher Notes
Step 1: What Need
39 x UV LED 3mm
1 x PCB 2x8cm Double Sided
1 x Mini Micro USB 1A TP4056 Lithium Battery Charging
1 x Slide Switch
1 x Battery 18650 (you can use old battery)
Step 2: Solid Leds on PCB
Solid Leds on PCB
Step 3: Solid Negativ Pozitiv Led Pin
Solid negativ pozitiv led pin
Step 4: Solid Slide Switch
Remove pin Slide Switch and Drill bit 1.5mm PCB for pin Slide Switch.
Step 5: Solid Battery and TP4056 Lithium Battery Charging
Step 6: Print Cace UV LIght
File for Print
https://www.thingiverse.com/thing:3462393
im use pla Filament Fluorescent Blue ESun.
Step 7: Super Glue
Use super glue under Lithium Battery Charging.
Step 8: Tape
Tape battery and TP4056 Lithium Battery Charging .
Step 9: Put PCB on Case
put PCB on Case and put Hed Cace.
Step 10: Screw
screw on Cace.
Step 11: Charge Battery
Charge Battery.
Step 12: End
Work Fine .
Like and Share Tanks.
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • CNC Contest
      CNC Contest
