Ultimate Straw Rocket!
129,354
194
96
About: I'm Nicolaj, a Danish chemistry student interested in DIY and projects involving fabrication.
What is the "Ultimate Straw Rocket"?
Answer: A very easy to make rocket made from a drinking straw, and launched using air pressure.
Almost everyone will be able to make this, it does not require any hard-to-find items, but also can it be made in very little time. Therefore will the rockets themselves be very easy to mass produce.
They will fly HIGH up in the air, and then land on the ground, completely safe!
Okay let's get started!
Teacher Notes
Step 1: Gathering Materials
As first said, the items are very easy to get, and you probably already have them lying around your house.
You will need to print following document to continue, though:
Download this .doc!
The rest of the materials are descriped in the picture.
Step 2: Making the Rocket
Cut a 6cm piece of a straw.
Put a dot of hot glue in one end of the straw making sure it's air tight.
Step 3: Attaching Fins
Now cut out a pair of fins from the printed document.
Then fold and glue the fins together. Stippled lines means "fold backwards", whereas straight lines means the opposite.
You can use hot glue to glue the fins together, but I find that white glue (Elmer's glue or wood glue) works well.
Then glue the backside (the white side) and attach it around the straw, approximately 1-1.5 cm from the open end of the straw.
Step 4: Launch It!
The rocket is finished now! Wasn't that easy?
Now for launching it:
Insert it all the way down in the nozzle of the bike pump, and give the bike pump a good, fast pump! Now enjoy your small flying rockets...
I had my rockets to go as high as ~10 metres!
Don't forget goggles, you don't want the rocket in your, or everyone else's eyes.
Thanks to Peter Hald for inspiration.
The Instructables Book Contest
Be the First to Share
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    • Furniture Contest
      Furniture Contest
    96 Discussions
    obasan
    2 years ago
    The fin pattern document is no longer available. I tried searching on Google, but couldn't find a similar fin. Does anyone have a source? Thanks
    samdadbobcurtis14
    Reply 3 years ago
    Did it work? If so how high did it fly?
    122717
    6 years ago
    Hey, I'm comment # 100!!!!!!! Awesome project
    hjjusaEcho2000
    I used Open Office to open it, it is a very handy free progam that will open most anything, free download online
    JudyTEcho2000
    thanks so much for this site. I'm a Preschool teacher doing an Outer space unit and think this is a super idea for little kids. Makes it so much easier to get ALL the details! Thanks again from Montana!
