Unapproachable Box
32
Introduction: Unapproachable Box
-BOX THE UNAPPROACHABLE-
Cute monster protecting your belongings~~
Teacher Notes
Step 1: Get Prepared
Arduino material:
Servo Motor ×3
Arduino Uno Board
Ultrasonic Sensor Library
Exterior material:
Card board / Paperboard
Pastel Paper(green/black/white/red)
Tools:
Ruler
Cutting Mat
Utility Knife
Scissors
Double-sided Tape
Superglue
Step 2: Cut the Board
Cut the board into
21×11.5×5
21×11.5×2.5
two size
Step 3: Forming the Palate
Form the card board into the monster's palate:
*Demonstrates with 21×11.5×5*
(Figure 1)Stick the 21×11.5×5 paper board on the green pastel Paper(leave about 2mm~3mm space between card boards).
(Figure 2)Leave proper spaces and cut it down.
Step 4: Forming the Palate
(Figure 1)Take the figure 1 as reference and fold the extra green paper along the cardboard.
(Figure 2)Fold the cardboard. The cardboard must be raised to the vertical. Then stick the 4 corner all together.(The highlight part in figure 2)
Step 5: Forming the Jaw
Repeat step 3&4 using 21×11.5×2.5 cardboard
Make a proper size of lid(tongue modeling) that can nicely fit in the jaw box.
Step 6: Connect the Circuit
Step 7: Combine Palate
(Figure 1)Make a strut to connect the palate and Servo Motor.
(Figure 2)(Figure 3)Connect them with the same angle in figure 2 and 3.
Step 8: Forming an Eye
(Figure 1) Prepare six 6×6 cardboard
6×4 cardboard
5×5 paper formed eyeball
a piece of cardboard
(Figure 2) Stick six 6×6 cardboard on the green pastel Paper(leave about 2mm~3mm space between card boards).
(Figure 3) Leave proper spaces and cut it down.
(Figure 4) Stick some up and some leave spaces in order we put the Servo Motor in.
Step 9: Forming an Eyeball
(Figure 1) Make a strut(same as step 7's) by the cardboard piece and stick it on the back of the eyeball.
(Figure 2)Connect them with the same angle in figure 2.
(Figure 3) Put it in the cardboard box we made in step 8.
(Figure 4) It should look like this.
(Figure 5) Stick those corners all up.
Step 10: Build Up
Make a base to fix palate's Servo Motor and fix the jaw, so it looks like a wide-opened mouth.
Then stick the Ultrasonic Sensor Library on the central closing, so whenever people approaches the mouth, the Ultrasonic Sensor Library near by will send message to the Servo Motor, and it will help move the palate.
DONE~
Step 11: My Production Process!!
Time-lapse photography.
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Warm and Fuzzy Challenge
    • Wearables Contest
      Wearables Contest
