Understanding and Visualizing RC Circuit on Evive's Oscillioscope
About: STEMpedia is a place bringing project-making tools at one place- kits, online courses, coding platforms, controller app and tons of free learning resources.
Love Physics? Then this project is for you. You’ll get to learn the basics of a capacitor, an RC circuit, how does it charge and discharge when connected to a DC supply, and what its response is when connected to an AC supply. And all of this can be done with the help of evive’s inbuilt oscilloscope, beta function generator, and a few electronic components.
Ready for some RC fun? Let’s get started!
Teacher Notes
Step 1: Things Needed
Hardware
  • evive
  • Capacitor
  • 10k Ohm Resistor
  • Push Buttons
  • Jumper Cable
Step 2: What Is a Capacitor?
A capacitor is a device capable of storing electrical charges. The maximum amount of charge that can be accumulated, divided by per unit potential difference is a property called capacitor capacitance (C) and is an indicator of the amount of energy it can store.
Step 3: What Is an RC Circuit?
RC Circuit is the electric circuit which consists of Resistors and Capacitors.
Step 4: RC Charging Circuit
The process of storing energy (when connected to a positive DC source) through the resistor until the voltage level across it reaches up to the input voltage level is called as charging of a capacitor. The circuit diagram can be drawn as:
Capacitors are charged according to time by the equation:
Step 5: Charging Waveform
When we charge a capacitor, the voltage (or charge) increases with time. The graph of voltage (or charge) versus time is not linear but exponential (as shown in the figure below). After a time T =RC, the capacitor is 63% charged (or 0.63 x voltage of the battery V). T is a constant for a given capacitor and a given resistor. T is called the time constant.
Step 6: RC Discharging Circuit
When the capacitor is fully charged and the power source is disconnected, the capacitor starts returning energy to the circuit through the resistor is called as discharging of a capacitor.
Capacitors are discharged according to time by the equation:
Step 7: Discharging Waveform
When we discharge a capacitor, the voltage (or charge) decreases with time. The graph of voltage (or charge) versus time is not linear but exponential (as shown in the figure below).
Step 8: The Connections
Make the following circuit using the resistor of value 10 kOhm and the capacitor of value 100 μF.
Once you make the connections, ON the evive.
Step 9: Visualizing Charging Waveform
As you ON the evive, the evive Firmware shows. Open the option of Oscilloscope and see the waveforms.
Step 10: Visualizing Discharging Waveform
Step 11: Conclusion
Now you know what an RC circuit is, how does it charge, discharge, and what its response is to an AC input. Simply put, you’re smarter than before B-)
BTW, did you check out how amazingly our campaign has been going?! In case you haven’t, go have a look at our campaign right away!
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
