Unicorn Floam Slime
Introduction: Unicorn Floam Slime
**Safety Warning: This project may become messy and is harmful if ingested, we ask that children complete this project with adult supervision.**
Supplies:
  • 1 mixing bowl
  • 1 spoon
  • Teaspoon and Tablespoon to measure
  • 1 bottle of Elmer’s 6oz glitter glue
  • ½ teaspoon of baking soda
  • 1 ½ tablespoons of contact solution (note: contact solution must contain boric acid and sodium borate)
  • Foam beads
Teacher Notes
Step 1: Gather Listed Materials
Step 2: Add Glue to Bowl
Empty One Bottle of Elmer’s Glitter Glue Into your Bowl
Step 3: Add Baking Soda and Mix
Add ½ teaspoon of baking soda into the bowl and mix thoroughly
Step 4: Add Contact Solution and Mix
Add ½ tablespoon of contact solution to bowl and mix together
Step 5: Add Even More Contact Solution
Add another ½ tablespoon of contact solution to the bowl and mix thoroughly again
Step 6:
Once ingredients are mixed in take slime out of bowl and kneed the slime. Slime should be very sticky at this point but this is normal, keep kneading for about 5-10 minutes.
*Note: If your slime becomes too sticky add another ½ tablespoon of contact solution
Step 7: Put Slime Back in Bowl
Once slime is kneaded place back into the bowl you’ve already used
Step 8: Add Foam Beads
Slowly add foam beads to the slime and mix the two together. Use caution when adding beads because these beads can easily roll away
Step 9: Add Even More Beads
You can now add more foam beads by flattening the slime a bit and adding beads to the center of the mix and folding slime over the beads
Step 10: Enjoy Your Slime!
Once beads and slime are mixed you are finished! Enjoy your unicorn slime!
*Pro tip: To make your Unicorn Floam Slime last longer store it in plastic tupperware
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Warm and Fuzzy Challenge
    • Wearables Contest
      Wearables Contest
    audreyobscura
    audreyobscura
    3 months ago
    Floam! So fun! I didn't realize you could just buy the styrofoam
