Upcycled Table and Chair Set
Introduction: Upcycled Table and Chair Set
Make it pls
Step 1: Make Da Chairs
To make the chairs you will need to have your milk crate and to have your plywood when you have them you are going to cut the plywood to size and to sand the corners around so you don't hurt yourself.
next, you will need to drill pilot holes on all 4 corners and screw you screws repeat this the same amount of the numbers of chairs you want.
If you would like you can even cut a rectangular hole in the front of the crate and put plywood inside to create storage.
Step 2: Make Da Table
For the top of the table, you can use an old pallet and some wide planks from different pallets.
Place the planks where you would like them to sit and draw lines where you need to cut.
Cut them to length and width and screw them into the pallet crossbars, if the planks aren't long enough to reach the crossbars attach the two together using pocket holes on the bottom.
Next, you can sand it smooth and move onto the next step
Step 3: Make Da Table Legs16x12
For this, you are going to need 4 pallet crossbars, hot glue and some plywood for the feet you need to cut the legs to the desired table height we thought that 64cm was the perfect length for the milk crate chairs.
The feet should be cut out of the plywood to 16x12cm and screwed on from the bottom and using the hot glue gun you can make bottom grips and cover up the screw
Now that you finished the legs and have made sure that they are all the same height you can screw them into the crossbars and the top of the table.
Step 4: Your Done!!
Enjoy
Be the First to Share
    • Puzzles Speed Challenge
    • Secret Compartment Challenge
    • Lighting Challenge
      Lighting Challenge
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    Looks like it would be great for a patio or backyard :)
