Upgrade Glasses
After many times of dropping my eyeglasses, now is the time of upgrade o repair just with one dollar. very easy to do.
Step 1: Basic Tools Needs
Small Phillips Screwdriver,
Hot glue or super glue
small pliers fine tip.
and a little be of force.
Step 2: Frames
Frames glasses base on the size of your eyeglasses lenses.
Step 3: Get Ready
On some frames need to unscrew the frame for release pressure on eyeglass, but on others just need to force the eyeglass lens from top to bottom and pressing with fingers.
Step 4: Protect
Use any kind of tape to protect the frame and the eyeglass lens from get some glue on parts where no need.
Step 5: Glue
This time I just used hot glue because I want to change for new frame later, but if you feel good with the first frame you can use super glue. ^_^.
Step 6: Modifier Frame
On this one I cut the frame just to make the lens to look good. ^_^ you can use any small saw or hot knife.
Step 7: Final Step
My favorite eyeglasses, on this one I make to fit on the frame with a little be of force no need glue, is no perfect but look good ^-^.
    • Comfort Food Challenge
    • Warm and Fuzzy Contest
    • Safe and Secure Challenge
    4 Discussions
    gralan
    4 months ago
    I have several pairs that need to be re-worked; your instructable not only gives clarity but also spawned a couple of ideas for me. Thanks.
    Recently I hot-glued a couple salvaged reader-lenses inside a pair of sunglasses, so that I can read outside. Gotta do whatever works, right?
    godlenovogralan
    Reply 4 months ago
    You right, Sometimes fixing or updating things with what is at hand is the best option. ^_^
