Use Balloons to Prevent Caulk/Construction Adhesive From Drying Out/Hardening in Open Cartridges
Introduction: Use Balloons to Prevent Caulk/Construction Adhesive From Drying Out/Hardening in Open Cartridges
About: Occupation: Tech Support
Since balloons are airtight, they make ideal tools for preventing open caulk and construction adhesive cartridges from drying out.
Parts:
1. Standard balloon
2. Open caulk/construction adhesive cartridge
3. Talcum powder
4. Rubber band
Teacher Notes
Step 1: Sprinkle Talcum Powder
1. Sprinkle a little talcum powder on the balloon to make it less likely it will stick to itself.
2. Spread the power around on both sides of the balloon with your finger.
Step 2: Roll Up Balloon
1. Roll the end of the balloon onto itself, similar to how a new condom is rolled up when taken out of its wrapper.
2. Roll it until you get to the larger head portion of the balloon.
3. Next, roll up the larger head of the balloon to squeeze out all the air.
Step 3: Put Balloon on Plastic End of Cartridge
1. Insert the open plastic end of the cartridge into open end of the balloon.
2. Roll the balloon down onto the plastic nozzle of the cartridge to the bottom, similar to how a condom would be deployed prior to use. Keep holding the larger portion of the balloon rolled up.
3. Fold the larger portion of the balloon in half and down around the plastic applicator.
4. Since this seal will not be completely airtight, use the rubber band to seal it off completely.
4. This should create a tight seal that will allow you to store the caulk or construction adhesive over an extended period of time.
Creative Misuse Contest
Be the First to Share
    • Trash to Treasure Contest
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    3 Discussions
    satosi
    satosi
    5 months ago
    Awesome, and exactly what I need right now, immediately before opening my silicone caulking & construction adhesive.
    Fingers crossed!
    sheripres
    sheripres
    1 year ago on Introduction
    I love this idea! I have been using caulk for a lot of projects lately and my boyfriend puts a nail in it. I think this is way better! Thanks for sharing!
