Introduction: Use GPIO Ports on Raspberry Pi Without Technical Knowledge Using NodeRED
The General Purpose Input/Output pins allow you to control and interact with the real world.
Learn more here: https://www.raspberrypi.org/documentation/usage/g...
Step 1: Switch on a LED
Let's do the usual material "Hello World": switching a LED.
Just build as the photo shows.
Learn more about the hardware here: Learn more here : http://thethingbox.io/docs/GPIO-Book.pdf
Step 2:
More details.
Step 3: A Simple Flow
Here is the simple flow we will build with the graphical editor.
Step 4: Download and Install the Pi SDCard
Go to http://theThingbox.io and download the SDCard image you can flash using the Etcher app ( https://www.raspberrypi.org/magpi/pi-sd-etcher)
Learn more here: Learn more here : http://thethingbox.io/docs/GPIO-Book.pdf
Step 5: Access the Visual Editor
Use your web browser to access the visual editor using the network name you gave in the setup process.
Step 6: Build a Simple Flow
We will build a simple flow with the GPIO node.
Step 7: Edit the Node
Edit the node to set the GPIO port to use.
Step 8: Deploy and Test
just hit the deploy button and now, by clicking the Go button you can switch the LED on and off.
