Use MFRC522 RFID Reader With Arduino
Hello! I am going to teach you how to make a cool, easy to make key card or key fob scanner! If you have a RFID MFRC522 module, leds, resistors, wires, a arduino uno, a breadboard, and a 9v battery(optional), then you are good to go to make a cool, easy to make key card or key fob scanner!
Step 1: What You Need
To make this project you will need: A RFID MFRC522 module, leds, resistors, wires, a arduino uno, a breadboard, and a 9v battery(optional).
You can find the RFID MFRC522 here. The other stuff is pretty basic so you should have it. If you don't, then I'm sure you can find it on amazon.
Step 2: Connect the RFID MFRC522 to the Arduino
Connect the RFID to the arduino:
Pin connections:
RFID:Arduino
VCC:3.3v
RST:D9
GND:GND
MISO:D12
MOSI:D11
SCK:D13
NSS(or SDA):D10
Step 3: Connect the Leds to the Arduino
Connect a red led to pin 8 and a green led to pin 7 with 1MOhm resistor in front of it. Then ground the leds.
Step 4: Connect the 9v Battery
Connect the 9v battery by connecting the battery to the battery holder and then the positive to VIN on the arduino and the GND to the GND on the arduino.
Step 5: The Code
You will find the libraries and code that you need in the zip file. After uploading the code, the red led should be on. If you tap a 13.56 Mhz ID card to the scanner, the green led will turn on.
    • Paper Contest
      Paper Contest
    • Build a Tool Contest
    • Remix Contest
      Remix Contest
