Vehicle Tracking System Based on GPS and GSM
Hello Friends, This is Anto. In this tutorial, you are going to learn how to make a vehicle tracking system using GPS and arduino. Arduino-based vehicle tracking system using global positioning system (GPS) and global system using GSM modules. GSM modem with a SIM card used here uses for the communication technique. The system can be installed or hidden in your vehicle. After installing this circuit, you can easily track your stolen vehicle using a mobile phone. you can also use this application to track the school/college bus.
Supplies:
I strongly suggest you to buy the components from UTSource website. because they are providing quality products and ON TIME DELIVERY. so that i used to buy the products from them.
Materials Required:-
Arduino UNO - 1 x 1
GSM sim800/900 module - 1 x 1
NEO GPS 6M - 1 x 1
16 x 2 LCD - 1 x 1
LCD Breakout Board -1 x 1
Jumpers - as needed
Teacher Notes
Step 1: Connect the TX and RX Pin of the GPS to D3 and D4
I have used software serial for communicating with GPS. so connect the connect the TX of the gps to D4 of the arduino board. RX to D3 of the arduino board.
Connect the TX and RX of the GSM module to the RX and TX of the arduino board
Step 2: Connect the LCD to the D8 to D13 of the Arduino Board
i strongly recommend to buy a LCD breakout board to connect the LCD.
LCD - Arduino
RS - D13,
EN - D12,
D4 - D11,
D5 - D10,
D6 - D9,
D7 - D8
Step 3: Add Tiny GPS Library
Add tiny gps library before making the code.
download the library from the website, add through add zip to library, browse it and add it.
Step 4: Download the Arduino Code From the Attachment
Note: before downloading, change the mobile number to receive the SMS.
Step 5: Type "TRACK VEHICLE" to the Sim on the Sim Module
Switch ON the hardware. Download the code. check the Network range on the GSM module with the blinking of the network led.
Type "TRACK VEHICLE" as SMS and send to the sim module in the GSM Modem.
Step 6: You Can Receive the Response SMS From GSM Module
Now you can receive the GPS co-ordinates as SMS. The sms consist of web link which will redirect to the GOOGLE MAP
Step 7: Click the Weblink to Track the Vehicle
Finally you can track the vehicle in the google map.. Enjoy... for queries.. comment
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
