Introduction: Vehicle Tracking With ESP32 GPS SIM808 - No Monthly Fee
About: Do you like technology? Follow my channel on Youtube and my Blog. In them I put videos every week of microcontrollers, arduinos, networks, among other subjects.
Today, we are going to address a very interesting subject: Vehicle Tracking with ESP32 GPS SIM808! And the best part about it: no monthly fee. Let's control the SIM808 module via UART using ESP32 LoRa. Also, we will get GPS location, and we will be able to calculate the distance from the device. In addition, this makes it possible for the sending of an alert SMS concerning a distancing device.
For this video, I did a test in my own car, but the recording was horrible, so I chose not to use it. But here, I’ll show you all the explanation, schema, and source code to get you started in your understanding about how tracking technology works.
Step 1: Assembly
Step 2: Enter the SIM Card
Insert the SIM card into the socket according to the image
Step 3: ESP32 LoRa Pinout
Step 4: SIM808 Dev Board
Step 5: Resources Used
ESP32 LoRa
SIM808 GSM Module GPRS GPS Development Board
Smartphone
SIM card (With credit)
Power Source / Battery 4V (SIM808)
Power Source / Battery 5V (ESP32)
Jumpers
LED
Resistor 330ohm
Step 6: Project Operation - GPS Location Reading
Data flow
The SIM808 picks up the signals from the satellites and calculates the latitude and longitude of the satellites. It is already integrated with a GPRS modem and GPS.
Step 7: Project Operation - Sending SMS
Data flow
Step 8: Library Required: TinyGsmClient
Download: https://github.com/vshymanskyy/TinyGSM
Note: The ESP32 LoRa OLED Display library SSD1306.h is appended to the project.
Step 9: Code
ESP32 code
Declarations and variables
#include <Arduino.h>
#include <HardwareSerial.h> //Comunicação UART com o módulo SIM808 #include "displayESP32LoRa.h" //Funções de display #include "GPRS_Functions.h" //Funções de configuração do GPRS const double LATITUDE_REFERENCE = -22.129688; //Latitude de referência para calcular o distanciamento do dispositivo const double LONGITUDE_REFERENCE = -51.408570; //Longitude de referência para calcular o distanciamento do dispositivo const double MAX_DISTANCE = 1000; //Distância limite usada para disparar SMS de alerta de distanciamento, medida em metros HardwareSerial mySerial(1); //Objeto referente a comunicação UART com o módulo SIM808 const String CELLNUMBER = "+5518999999999"; //Número de celular que recebe mensagens SMS de alerta referentes ao distanciamento do dispositivo //Flag que garante só um envio de sms quando o dispositivo estiver muito longe bool smsSent = false; //Tempo que é aguardado após o envio de um comando AT, usado na função "sendAT" const int TIMEOUT_AT = 2000; //Pino serial RX que deve ser conectado no TX do SIM808, usado para configurar a variável "mySerial" const int RX_PIN = 0; //Pino serial TX que deve ser conectado no RX do SIM808, usado para configurar a variável "mySerial" const int TX_PIN = 22; //Pino de sinalização que é ativado no mesmo tempo em que o SMS é enviado para o celular const int pinLed = 17; const int BAUD_RATE = 115200;
Setup
void setup()
{ pinMode(pinLed, OUTPUT); //Configura Display LoRa if(!loraDisplayConfig()) ESP.restart(); //Seta o baud rate que será usado pelo monitor serial e o que será usado pelo SIM808 serialConfig(); Serial.println("Waiting..."); showDisplay(0, "Waiting...", true); delay(3000); //Informa ao SIM808 o baud rate utilizado, é recomendado rodar este programa pela primeira vez com a velocidade de 9600 if(!baudConfig()) ESP.restart(); //Seta sms como modo texto if(!smsConfig()) { showDisplay(0, "SMS config failed!", true); Serial.println("SMS config failed!"); delay(3000); ESP.restart(); } showDisplay(0, "SMS config ok", true); Serial.println("SMS config ok");
//Ativa o recurso de GPS do módulo
if(!gpsConfig()) { showDisplay(1, "GPS config failed!", false); Serial.println("GPS config failed!"); delay(3000); ESP.restart(); } showDisplay(1, "GPS config ok", false); showDisplay(2, "Setting modem...", false); Serial.println("GPS config ok, setting modem..."); //Configura e inicializa o GPRS if(!modemConfig(mySerial)) { //Exibe no console e no display Serial.println("Modem init fail"); showDisplay(3, "Modem init fail", false); delay(5000); ESP.restart(); } //Exibe no console e no display showDisplay(3, "Modem ok", false); Serial.println("Modem ok"); }
Setup - serialConfig, baudConfig, and smsConfig
void serialConfig()
{ //Set console baud rate Serial.begin(BAUD_RATE); //Configura baud rate do ESP32 UART mySerial.begin(BAUD_RATE, SERIAL_8N1, RX_PIN, TX_PIN); //Esp32 lora 0 = RX, 22 = TX } //Configuração de mensagens SMS bool smsConfig() { //Define modo SMS para texto (0 = PDU mode, 1 = Text mode) if(sendAT("AT+CMGF=1").indexOf("OK") < 0) return false; //Se obteve sucesso retorna true return true; } //Configuração referente ao gps bool gpsConfig() { if(sendAT("AT+CGNSPWR=1").indexOf("OK") >= 0) //Liga fonte de energia do GNSS (1 = ligar, 0 = desligar) if(sendAT("AT+CGPSINF=0").indexOf("OK") >= 0) //Tenta obter pela primeira vez a localização GPS return true; return false; } //Informa ao SIM808 o baud rate utilizado, é recomendado rodar este programa pela primeira vez com a velocidade de 9600 bool baudConfig() { //Se obteve sucesso retorna true if(sendAT("AT+IPR="+String(BAUD_RATE)).indexOf("OK") >= 0) return true; return false; }
Setup - modemConfig and networkConnect
//#define TINY_GSM_MODEM_SIM800
#define TINY_GSM_MODEM_SIM808 // #define TINY_GSM_MODEM_SIM900 // #define TINY_GSM_MODEM_UBLOX // #define TINY_GSM_MODEM_BG96 // #define TINY_GSM_MODEM_A6 // #define TINY_GSM_MODEM_A7 // #define TINY_GSM_MODEM_M590 // #define TINY_GSM_MODEM_ESP8266 // #define TINY_GSM_MODEM_XBEE #include //Biblioteca que configura o modem GSM const char apn[] = "APN"; //YourAPN const char user[] = ""; const char pass[] = ""; HardwareSerial Serial_SIM_Module(1); TinyGsm sim808(Serial_SIM_Module); bool networkConnect() { Serial.print("Waiting for network..."); if (!sim808.waitForNetwork()) { Serial.println(" fail"); return false; } Serial.println(" OK"); Serial.print("Connecting to "); Serial.print(apn); if (!sim808.gprsConnect(apn, user, pass)) { Serial.println(" fail"); return false; } Serial.println(" OK"); return true; } //Configura o modem GPRS bool modemConfig(HardwareSerial mySerial) { Serial_SIM_Module = mySerial; //Inicia modem Serial.println("Setting modem..."); if(!sim808.restart()) return false; //Conecta na rede return networkConnect(); }
Loop
void loop()
{ String distance, la, lo; float lat, lon; //Tenta obter valores de GPS if(sim808.getGPS(&lat, &lon)) //if(getGSMLocation(mySerial, &la, &lo)) Caso o sinal GPS esteja ruim, teste utilizando a rede GSM substituindo este if { lat = la.toFloat(); lon = lo.toFloat(); Serial.println("GPS signal ok. Values obtained successfully."); //Verifica se o dispositivo ultrapassa a distância limite if(deviceIsTooFar(lat, lon, &distance)) { //Flag que permite o envio de só uma mensagem SMS if(!smsSent) { //Tenta enviar SMS if(sim808.sendSMS(CELLNUMBER, "Device is too far!")) Serial.println("Device is too far - SMS sent"); else Serial.println("Device is too far - fail to send SMS"); showDisplay(0, "Device is too far!", true); digitalWrite(pinLed, HIGH); //acende led sinalizando que o dispositivo está muito longe smsSent = true; delay(5000); } }
//Se foi possível obter os valores de GPS, exibe no display
showDisplay(0, "Latitude: " + String(lat, 6), true); showDisplay(1, "Longitude: " + String(lon, 6), false); showDisplay(2, "Distance: " + distance + "m", false); } else { //Se não foi possível obter os valores, exibe vazio Serial.println("GPS signal is down. Values not obtained."); showDisplay(0, "Latitude: -", true); showDisplay(1, "Longitude: -", false); showDisplay(2, "Distance: -", false); /* showDisplay(0, "Latitude: " + String(LATITUDE_REFERENCE, 6), true); showDisplay(1, "Longitude: " + String(LONGITUDE_REFERENCE, 6), false); showDisplay(2, "Distance: 328m", false); */ } flag = !flag; if(flag) showDisplay(5, "(Refresh)", false); delay(3000); }
Loop - deviceIsTooFar
//Calcula a distância em que o dispositivo está, levando em consideração a curvatura da terra (valor retornado em metros)
double getDistance(float lat, float lon) { double dist = 60 * ((acos(sin(LATITUDE_REFERENCE*(PI/180)) * sin(lat*(PI/180)) + cos(LATITUDE_REFERENCE*(PI/180)) * cos(lat*(PI/180)) * cos(abs((lon-LONGITUDE_REFERENCE)) * (PI/180)))) * (180/PI)); return dist*1852; } //Verifica se o dispositivo ultrapassou o limite de distância bool deviceIsTooFar(float lat, float lon, String *distance) { double dist = getDistance(lat, lon); *distance = String(dist); if(dist > MAX_DISTANCE) return true; return false; }
Display LoRa
#include "SSD1306.h" //Responsável pela comunicação com o display
//Define os pinos que serão utilizados pelo display LoRa #define SCK 5 // GPIO5 -- SX127x's SCK #define MISO 19 // GPIO19 -- SX127x's MISO #define MOSI 27 // GPIO27 -- SX127x's MOSI #define SS 18 // GPIO18 -- SX127x's CS #define RST 14 // GPIO14 -- SX127x's RESET #define DI00 26 // GPIO26 -- SX127x's IRQ(Interrupt Request) SSD1306 display(0x3c, 4, 15); //Construtor do objeto do display LoRa
Display LoRa - loraDisplayConfig
bool loraDisplayConfig() { //Configura RST do oled como saida pinMode(16,OUTPUT); //Reseta o OLED digitalWrite(16, LOW); //Aguarda 50ms delay(50); //Enquanto o OLED estiver ligado, GPIO16 deve estar HIGH digitalWrite(16, HIGH); //Inicializa display if(!display.init()) return false; //Inverte a tela verticalmente (de ponta cabeça) display.flipScreenVertically(); //Configura a fonte do display display.setFont(ArialMT_Plain_10); //Aguarda 200ms delay(200); //Limpa display display.clear(); return true; }
Display LoRa - showDisplay
//Exibe mensagem recebida como parâmetro
void showDisplay(int line, String msg, bool clear) { //Limpa o display if(clear) { display.clear(); //Configura alinhamento de texto à esquerda display.setTextAlignment(TEXT_ALIGN_LEFT); //Configura fonte do texto display.setFont(ArialMT_Plain_10); } //Escreve na pos 0,25 a mensagem display.drawString(0 , line*10 , msg); //Exibe no display display.display(); }
Step 10: Links
Step 11: Files
Download the files:
PDF
INO
