Introduction: Vending Machine
This is a complex but well worth it redstone vending machine. You put a emerald in the bottom and click on the button below the item frame to get what's in the item frame.
Inspired by Mr. Crayfish
Step 1: Step 1: Getting the Materials
You will need
- Hoppers
- redstone dust
- redstone torches
- redstone repeaters
- redstone comparators
- 4 beds
- 63 emeralds
- chests
- droppers
- dispensers
- fireworks
- sticky pistons
- blocks of redstone
- buttons
- ladders
- 3 item frames
- 3 different items
- block of choice (besides redstone block)
Step 2: Step 2: Getting Started
To start you will need to dig a 3x4 hole, three blocks deep.
Step 3: Step 3: It's All About the Money
First choose one of the 3 block long sides to be your front. In the bottom middle of the front, place a chest and put 2 hoppers on top (PS you’ll have to crouch to place the hoppers). Then, place 2 block going from the chest to the back. On the block closest to the chest place a redstone comparator and in front of it a redstone repeater(make sure they’re facing the right way).
Step 4: Step 4: Starting to Get "complicated"
For this step place a block in front of the redstone repeater, one block above the ground, and place redstone dust beneath it.
Step 5: Step 5: It's Working
Go to the front of the machine and place a block in the back bottom left corner and place a redstone torch on the side facing the front. Go on the block you just made and place a redstone repeater in front of the redstone torch. In front of the repeater place a block and put redstone dust on top.
Step 6: Step 6: It's Not So Hard
Go to the front and on the right side of the comparator, place a block of redstone with redstone dust on it.
Step 7: Step 7: Scam Catcher
For this step, right click on the hopper closest to the chest and put your 63 emeralds in the first slot and your beds in the other four.
Step 8: Step 8: Insert Here
Put a block on both sides of the top hopper. Then, build up 2 higher on each block and put one in the top middle leaving a one block gap in the middle.
Step 9: Step 9: What Ya Gonna Get?
On the top row of blocks you just made, place three buttons on the front and place a row of blocks behind the “n” shape you made making a stair like shape and place repeaters facing the back on top of that row.
Step 10: Step 10: Attack of the Torches
Behind the new repeaters place a row of blocks with redstone torches on the back face.
Step 11: Step 11: VIP (Very Important Part)
On top of the new redstone torches place a row of blocks. On the blocks right below the new set of blocks, place a row of redstone repeaters that should light up.
Step 12: Step 12: It's What Makes It Work
Above the non-lit repeaters, place a row of blocks. On top of that row, place a row of redstone torches.
Step 13: Step 13: Getting the Items (from the Vending Machine)
For this step, go to the front and place a row of blocks on top of the row with buttons. Place a row of droppers facing the front and put ladders on the front of that.(PS to place the ladders you’ll need to crouch.)
Step 14: Step 14: Digging Deeper
Go to the back of the hole, and dig out a 3x3x3 hole.
Step 15: Step 15: More Work
Build 2 rows of blocks at the bottom back of the new hole.
Step 16: Step 16: More Redstone
First, place block on the right side of the 2 rows you just made and place redstone dust on that. Then, place a redstone torch on the block next to it on the side facing the back. Then, place 2 comparators facing the way shown with redstone dust in the back right corner and a repeater next to it in the way shown.
Step 17: Step 17: the Pistons
First, place a sticky piston with the sticky side to the front then place a block of redstone on the sticky side.
Step 18: Step 18: Almost There
Go to the row of redstone torches and build 2 row of blocks going towards the back.
Step 19: Step 19: Attack of the Redstone
Go to the redstone block attached to the piston and dig down 2 block right to the left. Go in that hole and dig one block in the same direction. Run redstone dust up it and the place one on the block to the right of the one block deep space. Build a block over the 2 deep space and one to the back. Run the redstone up that and across the row you made earlier closest that’s to the back .
Step 20: Step 20: the Last Piston
On the side of the block over the 2 deep space facing the front, place a redstone torch. To the left of it, place a sticky piston facing the front. place a block on the sticky side.
Step 21: Step 21: Small Things Matter
3 blocks from the front, make a row of blocks across the hole and put redstone dust on top of it.
Step 22: Step 22: I'm Runnin' Out of Redstone
Place a repeater on the left side of the new redstone facing the way shown. Next, dig out the block in front of the repeater, the one under the block the sticky piston is holding, and the one to the right of the repeater.
Step 23: Step 23: Too Much Redstone
For this step, run redstone dust through the hole you just dug and place a block to connect the redstone to the block with the redstone torch on it.
Step 24: Step 24: Separate Paths
Place 2 blocks above the redstone piece you just made to separate the square shaped piece.
Step 25: Step 25: the Options
In between the droppers and the buttons, place a row of item frames. Right clicking on the item frames with something in your hand will put it in the item frames as shown.
Step 26: Step 26: Making Inventory
Now, fill the droppers with items. The dropper above the item frame should drop the same item that’s in the item frame beneath it.
Step 27: Step 27: Starting to Get Awesome
For this step, you’ll need to place a row of dispensers facing up over the row of un-lit redstone torches.
Step 28: Step 28: the Last Step
Now, fill the dispensers with fireworks. If you can’t craft fireworks, use flame charges.
First Prize in the
Minecraft Challenge
