Virtual Door Button Using Mongoose OS and XinaBox
Using Mongoose and some xChips, we made a virtual door button. Instead of a physical button to buzz staff in, they can now do it themselves.
Step 1: Things Used in This Project
Hardware components
Software apps and online services
  • Mongoose OS
    Really awesome and easy IoT development tool ... and free!
Step 2: Story
In our reception our staff needed to be buzzed in, so we decided to take our own medicine and create a virtual button.
This code allows you to send a RPC (Remote Procedure Call), which looks like a normal HTTP call from any browser. We used Mongoose, since it is really easy and fast to work with and it's built-in OTA (Over The Air) update of code, means we could install our tech and still over time upgrade the firmware, without dissembling it for reprogramming.
Step 3: Preparation
  • Install Mongoose-OS: Straight forward, just follow these very easy steps for your OS here: https://mongoose-os.com/software.html
  • Click the IP01 and the CW02 together using a XC10 connector. See image below:
  • Insert the IP01 into your USB port
  • Make sure the IP01 switches is in position B and DCE.
  • Flash the Mongoose-OS to CW02 from your command line. Like this:
cd <to your Mongoose installation>
export MOS_PORT=<your comport, such as /dev/cu.usbserial-xyz>
bin/mos flash esp32
  • You could also just enter the console and do most from there, but here we do it from the command line, so the work is quickly done. To enter the console:
bin/mos
Step 4: Configuration
While these steps could be done in one long statement, we decided to split them up, and since you would copy and paste them anyhow, lets make it easy:
Set the I2C pins to the xChips standard:
bin/mos config-set i2c.scl_gpio=14 i2c.sda_gpio=2
Connect your CW02 to your WiFi:
bin/mos wifi <Your SSID> <Your password>
Disconnect WiFi in AP mode and setup a domain name, so you can connect to the CW01 by hostname instead of finding the correct IP address. This will only work if:
bin/mos call Config.Set '{"config": {"wifi": {"ap": {"enable": false}}}}'
bin/mos call Config.Set '{"config": {"dns_sd": {"enable": true}}}'
bin/mos call Config.Set '{"config": {"dns_sd": {"host-name": "xinabox_switch"}}}
And finally you have to reboot the CW02 in order for the config to work
bin/mos call Config.Save '{"reboot": true}'
Very quickly after this you should be able to ping xinabox_switch.local
Step 5: Installing
Unplug the IP01 from your computer and assemble a circuit as per top image.
Plug the PU01 (or if you decided to stick with the IP01) into a USB power source. Connect wires parallel from your existing switch (leave that, just in case) to the OC03 (polarity doesn't matter). See Fritzing drawing.
Once powered up and to see that you are actually talking to your xCW02, what about scanning the BUS, aka the I2C bus:
bin/mos --port ws://xinabox_switch.local/rpc call I2C.Scan
If it all works and your xOC03 is installed correctly, you should see a number '56' be returned. That is the I2C address of the OC03 in decimal (in hex it is 0x38).
Step 6: Programming
  • Now open the Mongoose in console mode, see above. It should open with a Window where it ask for a port number, enter:
  • It will communicate with the CW02, and realise that the unit is already flashed and connected to WiFi, so it will just give 3 check marks. Close the window and refresh file list
  • Copy and paste the code below into init.js, and click on save+reboot
  • You circuit is now programmed.
Step 7: Test
You have now implemented another RPC call so from your terminal you can enter:
bin/mos --port ws://xinabox_switch.local/rpc call Switch
... and your buzzer should go for 2 sec. You could also just do it from - almost - any browser:
http://xinabox_switch.local/rpc/Switch
... with same effect.
Step 8: Next Step
You can use any tool that can fire off an URL. I do it from an Apple App called Workflow, that allows me to do it from my phone or as a complication from my Apple Watch, but there are many other options out there. Here is my Workflow script, but with hardcoded IP address: Enjoy!
Apple App: Workflow - here with hardcoded IP address
Step 9: Schematics
Buzzer Circuit
Install the OC03 in parallel with the existing push button.
Download it here.
OC03 Circuit
Download it here.
Step 10: Code
init.js JavaScript
Your main and only code for this project.
load('api_config.js');
load('api_gpio.js');
load('api_i2c.js');
load('api_net.js');
load('api_sys.js');
load('api_timer.js');
load("api_rpc.js");
let led = Cfg.get('pins.led');
let adr = 0x38;
let bus = I2C.get();
I2C.writeRegB(bus, adr, 3, 0);
I2C.writeRegB(bus, adr, 1, 0); /* turn off just to be sure */
let delay = 2000;
GPIO.set_mode(led, GPIO.MODE_OUTPUT);
RPC.addHandler('Switch', function(args) {
  GPIO.toggle(led);
  I2C.writeRegB(bus, adr, 3, 0); /* in case the OC03 gets reconnected */
  I2C.writeRegB(bus, adr, 1, 1);
  Timer.set(delay, false , function() {
    GPIO.toggle(led);
  }, null);
  return true;
    • Remix Contest
      Remix Contest
    • Organization Contest
    • Warm and Fuzzy Contest
