Vision Test
Introduction: Vision Test
Use this if you want vision like Ozil.
Step 1: Materials/Intro
Why Do we even need vision?
Vision actually helps us in life more than you know. For example, when you lost something, you have to bend down to find it. If you can see wider the chances are you are more likely to find that thing. Because you can see more places at the same time. Vision can not only be used in finding things. You can also use it in soccer. For example, when you have the ball you can have more option to pass when you can see wider. Or sometimes when you are about to receive a pass you can spot an opposition team's player charging on you or you can spot a teammate to pass to with the corner of your eyes before you touch the ball. Materials
Materials
Led x5 Breadboard x1
Arduino Mega/Leonardo/uno x1
1/4w resistor 5% x5
1/4w resistor 1% x1
Dupont line Double male 20cm x8
Two-legged button x1
Step 2: Set Up the Led.
All the 1/4w resistor 5% should be aligned with the negative electrode of the Led and all the other side of the resistors should be above the blue(negative) line.
Step 3: Connection
1st led should connect to pin 9
2nd is pin8
3rd is pin2
4th is pin7
5th is pin4
Step 4: Buttons
One side of the purple and yellow Dupont line should be aligned with 1/4w resistor 1%(the Blue resistor). The other side of the purple Dupont line should be on pin3. Another side of the yellow Dupont line should be connected to the button. And the another side of the orange Dupont line that's connected to the button should be on 5v. For the grey line, one side should be aligned with the blue resistor and another side should be on GND beside the orange line.
Step 5: How to Use It?
You will stare at the line drawn on the thin piece of cardboard. You will use the corner of your eyes to try to see the led in the second picture. If you can see if you press the button. Every time you press the button the level gets harder. You stop when you can't see the Led.
Step 6: Coding
int a = 10;
const int d = 5;
void setup() {
  // put your setup code here, to run once:
  Serial.begin (9600);
  pinMode(3, INPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(2, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(4, OUTPUT);
  digitalWrite(8, 1);
  digitalWrite(9, 0);
  digitalWrite(2, 0);
  digitalWrite(7, 0);
  digitalWrite(4, 0);
void loop() {
  // put your main code here, to run repeatedly:
  if (digitalRead(3))
    if ((a % d) == 0)
      digitalWrite(8, 0);
      digitalWrite(9, 1);
      digitalWrite(2, 0);
      digitalWrite(7, 0);
      digitalWrite(4, 0);
      delay(300);
    if ((a % d) == 1)
      digitalWrite(8, 1);
      digitalWrite(9, 0);
      digitalWrite(2, 0);
      digitalWrite(7, 0);
      digitalWrite(4, 0);
      delay(300);
    if ((a % d) == 2)
      digitalWrite(8, 0);
      digitalWrite(9, 0);
      digitalWrite(2, 1);
      digitalWrite(7, 0);
      digitalWrite(4, 0);
      delay(300);
    if ((a % d) == 3)
      digitalWrite(8, 0);
      digitalWrite(9, 0);
      digitalWrite(2, 0);
      digitalWrite(7, 1);
      digitalWrite(4, 0);
      delay(300);
    if ((a % d) == 4)
      digitalWrite(8, 0);
      digitalWrite(9, 0);
      digitalWrite(2, 0);
      digitalWrite(7, 0);
      digitalWrite(4, 1);
      delay(300);
    a++;
  Serial.println(a);
Step 7:
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    • Maps Challenge
      Maps Challenge
