Voltmeter Using Arduino
Introduction: Voltmeter Using Arduino
About: i am an electronics hobbyist.
In this tutorial we will make a voltmeter Using Arduino Uno.This type of voltmeter can be used to measure voltage under 0-5V.
Teacher Notes
Step 1: Components Required:
1.Arduino Uno
2.voltage source(less than 5V)
3.Wires
Step 2: Connection:
1.Connect the a Wire at Analog pin A0 in Arduino Uno.
2.Connect the a Wire at ground terminal of Arduino uno.
3.connect the voltage source between analog pin wire and ground wire.make sure about the terminal positive terminal of voltage source will be connect at Analog pin A0 wire and negative terminal of voltage source will be connect at ground terminal of Arduino Uno.
Warning: This type of voltmeter works between 0-5V.
Step 3: Program:
for code click on : Voltmeter Code
Upload the following program in Arduino Uno:
float vol=0;
int input=0;
void setup()
pinMode(A0,INPUT);
Serial.begin(9600); // starting the Serial Monitor
void loop()
input=analogRead(A0); //analogRead function is used to recive analog data
vol=(input*5.0)/1024.0;//formula using for perform action
Serial.print("voltage is:");
Serial.println(vol);
Step 4: Output:
Open the Serial monitor to get Output.
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Arduino Contest 2020
    2 Discussions
    Electronics Hour
    Electronics Hour
    Reply 1 year ago
    thanks for sharing your valuable comment.
    it's only for eduction purpose.
