Voltmeter Using NodeMCU
1,236
It is easy to make and cheapest voltmeter by which you can measure and store the voltage and also generate the graph of previous values.
Teacher Notes
Step 1: Things You Need.
In this project you will need :
  1. NodeMCU (esp8266)
  2. 1 k Resistor
  3. 10 k Resistor
  4. Solar panel (as an input )
Step 2: Circuit Diagram and Connections.
Step 3: Code for NodeMCU
Just copy and paste the code in your arduino ide and replace the device id with your device id and upload the code. (Watch video for help)
Step 4: Connecting to Thingsio.ai
Go to the following link https://thingsio.ai/ and create a new account.
1. Then click on new project
2. Enter project name and click on create.
3. Enter device name. ( for example voltmeter ).
4. Click on add new property.
5. In property name you have to write voltage and in property type select decimal.
6. Then select energy parameter and in transformation select none.
7. Finally click on update device.
8. A new window will open here on top left corner you will find device id.
9. Copy and paste this device id to your code.
10. Upload the code .
Watch video for full Explanation.
Step 5: Watch the Video for Full Instructions.
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
    pumudu88
    5 months ago
    Hello, Nice article.
    There's a minor correction. In your code ADC upper voltage has coded as 5v. Actually it should be 3.3v as ESP8266 v3 uses 0v to 3.3v reference voltage.
