WASHING SOAP by Using Kitchen Waste OIL
Introduction: WASHING SOAP by Using Kitchen Waste OIL
About: I'm a electrical and electronics engineer
WASHING SOAP made by using kitchen waste oil. we can washing soap much more simple and easy at home.
The ingredient we need for making washing soap
1. kitchen waste oil
2.caustic soda
3.sodium silicate
4.Gel
5.smell and color essense
6.car board of other utilities
Teacher Notes
Step 1: Step 1 Mixing Caustic Soda With Water
The first step is we need to mix caustic soda with water about 6 hours minimum
we need to take 1 liter of water in a bucket or other utility and add caustic soda into it .
for the dilution of caustic soda with water it will took 6 hours minimum
Step 2: Step 2 Mixing All Other Ingredients
After 6 hours process ,we need to mix caustic soda with other ingredients .
at first we need to mix sodium silicate
and the we need to add kitchen waste oil about 1 liter
and then the gel component
mixing this ingredients with caustic soda solution about 20 minute continuously
Step 3: Step 3 Mixing Video
now it is a important step to mix the ingredints
at first we need to mix kitchen waste oil 1 liter into caustic soda solution
and we add sodium silicate powder with the solution also the gel .
after that mix it well about 20 minutes continuously making into dry paste
and we need to mix color and smell liquid with it
after that pour it on to the cardboard or other utility for 1 week
after 1 week it will become a dried solid rough substance and we can cut into piece according to different shape and size as we requires
recycling the kitchen waste oil into soap and reusing
Step 4: Step 4 Cutting
After one week we need to cut this dried solution into different shape as we require
washing soap can be made as much easy by using kitchen waste oil. we are recycling waste oil into usable product . by using we can make other usable soap products .
Oil Contest
Oil Contest
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Wearables Contest
      Wearables Contest
    10 Discussions
    jashinjayaram
    jashinjayaram
    Reply 1 year ago
    thank you
    AnupriyaP1
    AnupriyaP1
    1 year ago
    Good work
    JishnuK3
    JishnuK3
    1 year ago
    Fantastic work man .keep it up
    jashinjayaram
    jashinjayaram
    1 year ago on Step 3
    step 3 i had uploaded a video but unfortunately something went wrong ,i kindly ask `sorry for` this and i apologize.
    in step 3 we need to miss sodium silicate ,gel and kitchen waste oil into the caustic soda solution .mix this well continuously for 20 minute.after mixing well pour the solution into cardboard or other utility
    this will take about 1 week for drying and being into soap
    thank you instructables for gaving me opportunity and rejecting this unique recycling idea
    recycle reuse save the enivornment
