Water Bottle Rocket
Have you ever wanted to make a rocket? Now you can, in just under 15 minutes with supplies you have around the house!
Supplies:
2 litter bottle, cardboard, scissors, tape, cork, and a bicycle pump.
Teacher Notes
Step 1: Rocket Fins
Cut out three carboard triangles. Then, attach them to the bottle using tape or glue. These will be the fins for the rocket.
Step 2: Cork
Press the needle of the bike pump into the cork to create a hole. Then, put the cork inside the bottle with the side of the hole facing out.
Step 3: Adding Propellant
Fill your 2 liter bottle with water. I filled mine halfway, but you can experiment to see what works the best. After filling up the bottle, place the cork inside the top.
Step 4: Launcher
Using a cardboard box, cut a hole in the top that the rocket snuggly fits inside. This will be used to hold the rocket while it is being launched. Then, cut a hole in one of the sides of the box. This will be used for the bicycle pump to reach the cork of the rocket.
Step 5: Decorating the Rocket (optional)
Now that the construction of the rocket is finished, you can decorate the rocket or the launcher.
Step 6: Blast Off!
It is now time to launch the rocket! The rocket can go up to 1,000 ft, so make sure to launch it away from people and buildings. Place the rocket inside the launcher. Attach the needle of the bicycle pump to the hole in the cork. Pump air until the rocket until it launches.
Make It Fly Challenge
Be the First to Share
    • Skateboard Contest
      Skateboard Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    3 Discussions
    Cats Science Club
    Question 24 days ago
    I like your instructable. Does the bottle launch unexpectedly or is their a pressure the rocket is more likely to take off at?
    1 answer
    myracropper32Cats Science Club
    Answer 24 days ago
    It depends on the amount of water, but for me it took about 7 pumps for it to launch. You can start to feel the pressure build up, and it will get gradually get harder to pump before it launches. Good luck and thank you for the positive comment!
    Cats Science Club
    24 days ago
    Way easier and less expensive then a lot of the water/pop bottle rocket launchers I have seen. Thanks for sharing.
