Water Slide Picture Transfer
Introduction: Water Slide Picture Transfer
In this instuctable you will learn how to transfer artwork using water slide paper.
Step 1: Find a Design You Like.
Once you find your design, you’ll need water slide transfer paper.
Step 2: Find Something to Transfer the Design Onto
I would recommend not attempting this on skin or clothing. Find a hard smooth surface such as a mug or plate.
Step 3: Print Your Design
Water slide paper is available for ink jet printers and laser printers so check to see what type of printer you have.
Step 4: Cut Out Your Design
You’ll need a sharp pair of scissors and cut as close to the design as possible because you don’t white trim around your art. (Unless you do then leave it)
Step 5: Transfer Design
This step is like a temporary tattoo application. You’ll need water and a sponge/cloth to apply to back of paper.
Step 6: Peel Off Paper Slowly
And voila!!!!!! You now have your design on whatever you want. :) Once it’s semi-dry you can begin to smooth out bubbles with your finger.
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
    2 Discussions
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    Looks like a good technique! Do you need to coat it with anything to get it to stay?
    QueenBeeeeaaaan
    QueenBeeeeaaaan
    Reply 1 year ago
    A coat is not needed but I would recommend hand washing it.
