Water Tank Level Monitoring
The project is to automatically monitor the water level on this device. The goal is to help us leave the water running safely while engaged by other tasks. The feature works based on water's echo wave. The device composes of ardouino board, ultrasonic sensor, bread Board, jumper wires, paper board.
Teacher Notes
Step 1: Fundamental Settings
Put together wire, LED, sensor with ardunio board.
Step 2: Device Package
connect the previous setting together with bread board, and put it into the well-cut box.
Step 3: Settings Onto Tank
Put the package with configuration attached to the tank and connect the sensor on the top of it.
Step 4: Testing
Fill the water into tank to observe the testing result.
Step 5: Code
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
