Watertight Glass Magic Trick
Here is a fun, simple trick that is sure to astound somebody! Try doing this one multiple times if the first time doesn't work. Have fun!
Teacher Notes
Step 1: What You'll Need:
For this cool magic trick, you will need a glass or cup of water, some water, and some paper that's big enough to fit over the cup or glass.
Step 2: Fill the Glass
First, fill the glass about halfway with water. If you fill the cup more than halfway, the trick won't work as easily. If you fill the cup less than halfway, the trick isn't as astounding.
Step 3: Cover the Cup
Now, place the paper over the cup. Make sure that there aren't any gaps. If there are gaps, the trick won't work.
Step 4: the Magic!
Now, carefully flip the cup (and paper) over, minding not to slosh the water around too much. Don't move the cup too much. Do not worry if the water leaks. Try again, and if you used a glass, use a cup next. Cups are lighter.
Step 5: Variations on This Trick
If you've completed this trick, try some variations! One variation is trying to stick pins through the paper after flipping the cup over. Also try exploring different amounts of water in the cup. Have fun playing with this trick!
Be the First to Share
    • CNC Contest
      CNC Contest
    • Teacher Contest
      Teacher Contest
    • Maps Challenge
      Maps Challenge
    2 Discussions
