Wave Demonstrating Machine
Introduction: Wave Demonstrating Machine
First, every project starts with a problem, and here we can see our problem which is that we should make an machine that demonstrate waves using mathematical functions , then we focused on the constrains which were is to use MDF Wood and PLA (which is a type of plastic used in the 3D printers)
definitions we need to understand:
1.sound:
A wave is an oscillation that travels through space and is described by its frequency, amplitude, wavelength and speed
2.superposition principle: for all linear system, the net response caused by 2 or more stimuli is the sum of the responses that would have been caused by stimulus individually
3.simple wave: a wave with constant state
Teacher Notes
Step 1: Materials That We Used
So these are the materials which we needed to build our prototype
Step 2: STL Files and Pictures of the Parts
each file is placed after the picture of it
PS:(the first part has 2 pieces)
and for the plate which is the base we printed it using cnc machine .
Step 3: Assembly
then we have assembled the parts together to check if they fit in the right places
Step 4: Finalizing
we sand papered the parts so that it can fit perfectly
Step 5: Testing the Machine
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Wearables Contest
      Wearables Contest
