Waving Wood Flag
Introduction: Waving Wood Flag
In this tutorial I’ll show you how I made my “Waves for Days” flag out of 2x4’s
Supplies:
8- 8’ 2x4’s
Rit Dye blue and red
Polyurethane
Star Stencil
Bandsaw or jigsaw
Rotary Tool
Mitre Saw
Angle grinder
Brad Nailer
2” Brad nails
Step 1: Making the Template
To make the template for the waving effect I cut out a 2x4 13” longer than I wanted my stripes to be. My flag was 36” so I cut this piece at 49” Then I drew on a wave pattern that I thought looked ok and cut it out on a bandsaw. I then marked lines 1” a part all the way to 13”.
Step 2: Making the Stripes
I cut out each stripe to length on the mitre saw. Then I took my stripe template and traced the wave pattern on to it. Then for all the consecutive stripes i moved the template 1” down and traced the pattern for each of the 13 stripes, and labeling each stripe as i finished.
Step 3: The Grind
Next I cut out each stripes wave on the bandsaw. Once you finish, line all the stripes up in order and you should have a cool wave effect. Then the fun part begins. I clamped each stripe together and used an angle grinder with a shaping wheel to grind down all the offset pieces so it all looks nice and smooth. Then i used my palm sander and sanded through 600 grit to finish.
Step 4: Burn and Stain
After the sanding is finished, burn each stripe just enough to bring the grain of the wood out. Once burned, i lighted sanded it again and wiped it all down before the stain. I used Rit Dye for the stain and stained each stripe individually before i glued it together. This saved a TON of time taping. Once stained i used a high gloss polyurethane on all the stripes individually as well. The stain will bleed so i didn’t want to risk any of the color blending together.
Step 5: Glue Up
Once the poly dried I glued and nailed each stripe together one at a time. Be careful not to use too much glue. You don’t want any to sleep out on the poly. Once everything was dry I traced on the stars with a stencil and cut each one out individually. Hope you enjoyed this tutorial!
1 Person Made This Project!
  • Mason Jar Speed Challenge
  • Bikes Challenge
    Bikes Challenge
  • Remix Contest
    Remix Contest
3 Discussions
MikeL407
MikeL407
Question 7 months ago on Step 5
How do you mix the dye? Ratio of dye to water? Thanks
jthomas104
jthomas104
Answer 7 months ago
I don’t mix the dye at all. I use it right out of the bottle.
SarahH409
SarahH409
8 months ago
Thank you :D
