Wearable LED Matrix Display Badge
3,954
36
18
Introduction: Wearable LED Matrix Display Badge
Are you running an event ,competition or even hosting a birthday party ?
Badges are versatile item that can make introductions and celebrations that much easier .You would never begin a conversation with "hello , my name is ............." so why should your badge?
So lets design a PCB Badge that you can pin proudly and wear at your next important event.
In this project, I will be showing how I built a badge-sized ATtiny85-based LED matrix display (5x4 matrix). I have used Charliplexing technique for driving 20 LEDs using ATtiny85.
you can even easily add extra texts to your badge as you wish.Standout from the crowd with this awesome PCB badge.
Lets get started :)
Step 1: Watch the Video
The video goes through the build process as well, if you prefer to learn that way!
Step 2: Things Used in This Project
Hardware components
  • Microchip ATtiny85 x1
  • Coin Cell Battery CR2032 x1
  • 3 mm LED x20
  • CR2032 Coin Cell Holder x1
  • 8 pin DIP IC Socket x1
  • Slide Switch x1
  • Resistor 100 ohm x5
To program ATtiny85 you need an arduino uno or any other arduino boards.
Software apps:
  • Arduino IDE
Hand tools:
  • Soldering iron
Step 3: Charlieplexing
Charliplexing is a technique for driving a multiplexed display in which relatively few I/O pins on a microcontroller are used, e.g. to drive an array of LEDS. The method uses the tri-state logic capabilities of microcontroller in order to gain efficiency over traditional multiplexing.
The formula for Charlieplexing isLEDs = n^2 - n
where 'n' is the number of pins used.
I use an ATtiny85 programmed with the arduino as ISP.So it uses 5 pins for 20 LEDs.
More info on Charlieplexing: http://en.wikipedia.org/wiki/Charlieplexing
Step 4: Schematic Diagram
Step 5: The Prototype!
Before designing a PCB, I decided to build a prototype on a perfboard.
And it worked fine......
Step 6: PCB Design
I used KiCad for PCB Design.The edge cut were made using .DXF file which was designed and generated using Autodesk Fusion 360.
The size of PCB badge was 55*86 mm.
I quoted and ordered PCB through PCBWay.com.
Note:
The White Silk Screen On the center is provided to Write your Name or Whatever you want :)
After soldering the PCB looks like this:
This project is open source. If you would like to build your own, all of the resources are available in the my GitHub page.
Step 7: Wire the Circuit to Flash ATtiny
(DON'T insert the battery now.)
On the PCB I have provided 6 pin connector for programming ATtiny85.the small dot near the 6-pin connector is the first pin (MISO), see the photos for alternative connections.
  • Arduino +5V ---> VCC
  • Arduino GND --->GND
  • Arduino pin 10 --->RST
  • Arduino pin 11 --->MOSI
  • Arduino pin 12 --->MISO
  • Arduino pin 13 --->SCK
Follow the below link for programming ATtiny:
The Instructables Community Manager randofo had written a nice instructables on "Program an ATtiny With Arduino".
you can download all source files from my githhub page:https://github.com/amalmathewtech/ATtiny_LED_Matrix_Display_Badge
After Configuring Arduino IDE Tools Menu, upload given arduino sketch
Note: update 11th line of arduino sketch to display as your wish
Step 8: Sneak Peek Video
Have fun :)
Thank you so much for reading if you need any more information feel free to ask in comments, and I'll do my best answer you.
If you like this project you can support my project by Voting it for Party Challenge .
You can also support my project on PCBWAY's I can Solder KIT 2019 contest
Happy making! :)
Party Challenge
Party Challenge
Be the First to Share
    • Puzzles Speed Challenge
    • "Can't Touch This" Family Contest
    • CNC Contest 2020
      CNC Contest 2020
    18 Discussions
    tehhustler
    tehhustler
    Question 4 months ago
    How are you getting g 5V out of a CR2032?
    tehhustler
    tehhustler
    Answer 4 months ago
    Wait, does it just pull 3V? Is that why your LED resistors are so low?
    Bigbadhodad1
    Bigbadhodad1
    7 months ago
    I’m building it but will be substituting a arduino pro mini and I’m not sure about the pin changes, I got MOS1 as pin 8 MOS0 as pin 9 SCK as pin 13 PB3 as pin 11 and PB4 as pin 12 am I correct?
    Bigbadhodad1
    Bigbadhodad1
    Reply 6 months ago
    I built it but it doesn’t work
    AmalMathew
    AmalMathew
    Reply 6 months ago
    Did you modify code according to pro mini .
    Bigbadhodad1
    Bigbadhodad1
    Reply 6 months ago
    I thought I did, though I’m still learning it. Do you by any chance have the code for it?
    mohir
    mohir
    Question 1 year ago
    When inserting the LEDs where should the plus side be on the square or in the circle?
    Please reply :)
    KarloHorcicka
    KarloHorcicka
    Answer 1 year ago
    I believe that the square is for positive lead
    mohir
    mohir
    Reply 1 year ago
    Thank you for replying, I hadn't the patience and tried put the other way around (Square as negative) and it works well, i saw that the square on the battery holder is connected to the Ground on the attiny. The strange thing is that before soldering entered the Leds the other way around and they still lit up...
    AmalMathew
    AmalMathew
    Reply 1 year ago
    Yeah, it works if you insert it in other way too. You just read about charliplexing ,they you will have idea that why it works on both methods .
    mohir
    mohir
    Question 1 year ago on Step 8
    on the pcb the squares are the plus or the minus side?
    thank you
    AmalMathew
    AmalMathew
    Answer 1 year ago
    Here the square one is cathode(-ve).
    usually square will be used as anode (+).
    mohir
    mohir
    1 year ago
    Very nice idea!!!! Thank you for sharing,
    As they are many types of CR2032 Coin Cell Holder and of switches, could you please give a link to ones that fit your PCB.
    Also tried to order the pcbs but it doesn't allow me to checkout :(
    Arbormakes
    Arbormakes
    1 year ago
    Amazing!
    How much does it cost to order the PCBs?
    jessyratfink
    jessyratfink
    1 year ago
    That's a pretty neat idea. Definitely more fun than a standard name tag :)
    AmalMathew
    AmalMathew
    Reply 1 year ago
    Thank you :)
