Weather-Station
Introduction: Weather-Station
About: Student MCT Kortrijk
In this project we will make a weather station that will measure the temperature, humidity and UV index by using Raspberry Pi, Python (coding), MySQL (database) and Flask (web server).
Supplies:
The required components for this project
are:
- Cover cap
- DHT11 humidity sensor
- DS18B20 temperature sensor
- GUVA-S12SD UV sensor
- LCD Display
- Servo motor
- MCP3008
- Raspberry Pi 3
- Trimmer
- Total cost is around € 110.
The tool I used:
- Conical drill
- Double-sided adhesive tape
Step 1: Circuit
Circuit:
LCD:
- VSS to Raspberry Pi’s ground
- VDD to Raspberry Pi’s 5V
- V0 to middle pin trimmer
- RS to GPIO pin
- R / W to Raspberry Pi’s ground
- E to GPIO pin
- D4 to GPIO pin
- D5 to GPIO pin
- D6 to GPIO pin
- D7 to GPIO pin
- A to Raspberry Pi’s 5V
- K to Raspberry Pi’s ground Trimmer
- To Raspberry Pi’s 5V
- To LCD pin V0
- To Raspberry Pi’s ground
DHT11:
- VCC to Raspberry Pi’s 3V3
- GND to Raspberry Pi’s ground
- DAT to Raspberry Pi’s GPIO pin 4
- 470 ohms between VCC and DAT
DS18B20:
-470 ohms between VCC and DAT
Servo motor:
- VCC to Raspberry Pi’s 5V
MCP3008:
- VDD to Raspberry Pi’s 3V3
- VREF to Raspberry Pi’s 3V3
- AGND to Raspberry Pi’s ground
- CLK to GPIO pin 11 SCLK
- DOUT to GPIO pin 9 MISO
- DIN to GPIO pin 10 MOSI
- CS to GPIO pin 8 CE0
- DGND to Raspberry Pi’s ground
- CH0 to GUVA-S12SD (UV sensor)
Step 2: DHT11
DHT11 is a digital
temperature and humidity sensor. Output to a digital pin.
DHT11 specifications:
- Operates on: 3.3 - 6V.
- Temperature range: -40 - +80 ºC.
- Temperature accuracy: ± 0.5 ºC.
- Humidity range: 0-100% RH.
- Humidity accuracy: ± 2.0% RH.
- Response time: <3 sec.
Step 3: DS18B20
DS18B20 Sensor Specifications
- Programmable Digital Temperature Sensor.
- Communicates using 1-Wire method.
- Operating voltage: 3V to 5V.
- Temperature Range: -55°C to +125°C.
- Accuracy: ±0.5°C.
- Unique 64-bit address enables multiplexing.
Step 4: LCD
LCD controller with 16 × 2 characters display module with blue
backlight and white characters. 2 lines, 16 characters per line. High contrast and large viewing angle. Contrast adjustable by means of an adjustable resistor (potentiometer / trimmer).
LCD 16 × 2 blue specifications:
- Operates on: 5V
- Adjustable contrast.
- Dimensions: 80mm x 35mm x 11mm.
- Visible display: 64.5mm x 16mm.
Step 5: MCP3008
An analog-to-digital converter or AD-converter (ADC) converts an analogue
signal, for example a speech signal, into a digital signal. The MCP3008 has 8 analog inputs and can be read with an SPI interface on an Arduino, Raspberry Pi, ESP8266 The MCP converts an analog voltage to a number between 0 and 1023 (10 bit).
When using the MCP3008 you need to enable SPI, you can do this by (images added with the steps) :
  1. Typ in the console: sudo raspi-config
  2. This will launch the raspi-config utility. Select “Interfacing Options”
  3. Highlight the “SPI” option and activate .
  4. Select and activate.
  5. Highlight and activate .
  6. When prompted to reboot highlight and activate.
  7. The Raspberry Pi will reboot and the interface will be enabled.
Step 6: Servo Motor
Size: 32 × 11.5 × 24mm (Tabs included) 23.5 × 11.5 × 24mm (Tabs not include)
Weight: 8.5g (Cable and a connector not include) 9.3g ( Cable and a connector included)
Speed: 0.12sec/60degrees (4.8V) 0.10sec/60degrees (6.0V)
Torque: 1.5kgf-cm (4.8V) 2.0kgf-cm (6.0V)
Voltage: 4.8V-6.0V
Connector type: JR type (Yellow: Signal, Red: VCC, Brown:GND)
Step 7: UV-SENSOR GUVA-S12SD
GUVA-S12SD Sensor Specifications
- Operating voltage: 3.3 V to 5 V
- Output voltage: 0 V to 1 V (0-10 UV index)
- Response time: 0.5 s
- Accuracy: ± 1 UV index
- Wavelength: 200-370 nm
- Consumption: 5 mA
- Dimensions: 24 x 15 mm
Step 8: Case
I used a cover cap for the hull where I drilled 2 holes for the temperature and the uv sensor, the humidity sensor, servo motor and lcd were mounted in 1 of the holes at the top. The cover cap was mounted on a board for a better look
Step 9: Database
Step 10: Code
Be the First to Share
    • Puzzles Speed Challenge
    • "Can't Touch This" Family Contest
    • CNC Contest 2020
      CNC Contest 2020
