Weave Your Own Wig
13,592
51
11
Introduction: Weave Your Own Wig
About: I'm currently in college studying everything I can. I work in a makerspace where I've really been able to grow a lot. Keep an eye out for new Instructables on the way! Thanks for checking out my page!
Sometimes store bought wigs can be.... disappointing. The colors are limited, the hair falls out, they can't be styled with heat, and you can usually only part them in one place. There are tutorials online that can help transform a store bought wig, but they can only go so far. However, this tutorial will guide you through making your own completely customizable wig without all of the expensive equipment and materials.
Step 1: What You Need:
-Acrylic Yarn. It's important that the yarn you use is 100% acrylic. Which is good because that's the least expensive kind and it comes in every color. I used a $4 ball of CraftSmart yarn from Michael's.
-Weaving Cap. A fishnet wig cap would work too. Here's the one I used. It's durable and adjustable. https://www.amazon.com/gp/product/B00QU9P3I4/ref=p...
-Thread. It's best if it matches your yarn.
-Thin craft wire.
-A brush. Wire pet brushes work best but an ordinary one works.
-Hairspray.
-Scissors.
-Flat Iron.
-Foam head or similar round object to hold your wig.
Step 2: Make Your Wefts.
In order to make wigs, professional wig makers use something called wefts, which are attached sections of synthetic hair that are sewn onto the cap to give the appearance of them growing out of the wearers head.
To make your wefts you first need to cut your yarn into many pieces that are the same length. In order to do this quickly it helps to wrap your yarn around a glass and cut through the bundle.
Then you should tie each piece in the middle around another piece as shown in the photos above. Keep adding pieces of yarn until you have a long enough weft. When you have a few of these, you can start brushing them out by holding one end of the weft and gently brushing the other until the fibers separate. (another great by-product of this project is all the fluff that's left over when you brush out the weft. it makes great stuffing for your projects and is similar to Poly-Fil.)
Step 3: Ironing and Pinning
After you have a sizable pile of fuzzy wefts, you should start to straighten them.
Put your iron on the lowest setting and straighten them the way you would your own hair. If the weft gets tangled you can just give it a quick brush and hit it again with the flat iron.
After straightening the wefts, pin them where you want them on the weaving cap. It's best to place them radiating out from the center, but it doesn't have to be perfect. Once you're happy with what it looks like you can sew them down with any stitch you want to, as long as the needle goes through the knots where you originally tied the yarn.
Step 4: Adding Your Part
The best.... part ;) about this wig is that you can part it in a way that actually looks natural. Since I was making this wig for my Party Poison costume, I used a picture of him as a reference. He has a kind of messy side part so I parted it on the side and filled it in randomly with tiny wefts. If yo want a wig that can be parted in any direction, simply make a few extra wefts to completely fill the top of the wig.
The most important thing to do is make sure that your part wefts are small. That way the gaps between the wefts can be minimized so they aren't seen.
The second picture is what it looks like when you're done. :)
Step 5: Cut and Style Your Wig
Once it's all put together you can cut your wig to make it look how you need it to. This was much easier than I expected it to be because the fine synthetic fibers are very cooperative,and if you mess up too badly you can always just replace the weft with a new one.
Once it's cut, you can use hairspray, curlers, or flat irons to style it. All I did to make mine look more spiky was put some hairspray on my fingers and pinch the ends of a few strands to give them a little definition. I sealed the whole thing with more hairspray and it was ready to go! This is one of my favorite wigs to wear because it's easy to style and really quite comfortable. Since it was made to fit my head I can wear it despite the fact that I have a lot of really long hair tucked into my wig cap.
Enjoy! Please make sure to like this Instructable and leave a comment if you make one!
Weaving Challenge
Weaving Challenge
Be the First to Share
    • Recycled Speed Challenge
    • Make it Move Contest 2020
    • Build a Tool Contest
    11 Discussions
    hihifishyfishy
    hihifishyfishy
    4 months ago
    hai i use this all the time, its cheap and fairly easy. Now, i dont have to waste my own money on wigs
    SophieBdoesart
    SophieBdoesart
    Reply 7 weeks ago
    I'm so glad you found this useful!
    Blue_tea_cosplays
    Blue_tea_cosplays
    Question 7 weeks ago
    I have a question if you do use Kanekalon where would you buy it ?becuase i am wanting to make a wig that goes to mid back length :)
    SophieBdoesart
    SophieBdoesart
    Answer 7 weeks ago
    Your best bet is to get it online, but make sure you get the silky smooth kind. Kanekalon is heat resistant though so you can use heat tools if they're on a low setting. If you want to sew your wefts you'll need tulle and a sewing machine. If you want to make no sew ones you can use weft glue or eyelash glue in a pinch.
    obnoxiouslyannoying
    obnoxiouslyannoying
    Question 6 months ago
    hi! your wig looks wonderful! do you know if the wefts can be made longer? i'd like to make a wig using this method but i'm aiming for a longer style.
    SophieBdoesart
    SophieBdoesart
    Answer 6 months ago
    Unfortunately I don't have any way to make this longer. The maximum length is based on the average length of the fibers in acrylic yarn. However, there is a material called Kanekalon that is also heat resistant and inexpensive. It's usually used in braiding shops but you can find it online and straighten it similarly to the acrylic fibers. If you DM me I would be happy to give you some pointers on what you need and how to use it. If you have time to wait I will be uploading an Instructable. 😁
    hihifishyfishy
    hihifishyfishy
    Reply 4 months ago
    i am a cosplayer and this is a very inexpensive way to create tassles, wigs and other things
    jessyratfink
    jessyratfink
    1 year ago
    This is fantastic! Thank you for sharing this :D
    SophieBdoesart
    SophieBdoesart
    Reply 6 months ago
    Thanks for enjoying it! You may also want to look into kanekalon as a wig material if you're interested in longer ones. I just started doing that and it is much more natural looking. I'd be happy to give you tips if you want to DM me. 😁
    SophieBdoesart
    SophieBdoesart
    Reply 1 year ago
    Thanks for liking it!
    Eh Lie Us!
    Eh Lie Us!
    11 months ago
    wow. that's pretty cool. thank you for sharing.
