Weekly Project: Build Your Own X-Ray Vision Camera
281,584
174
142
Introduction: Weekly Project: Build Your Own X-Ray Vision Camera
You've seen them in the back of magazines--heck, probably Popular Science--all your life: the crazy swirling paper X-ray specs, with the campy '50s pervert looking at the bloomers of a shocked gal. While we don't support such nefarious uses, you can make your own working X-ray camera, just by modifying a CVS Disposable. It won't give you Superman vision, but you should be able to see through one or two layers of paper and fabric (again, behave!) in the right light. Here's the catch: The key is in a hard-to-find X-ray conversion material called a beryllium window. PopSci got its sample from NASA during a visit to the Goddard Space Flight Center a few years ago, as it is sometimes used in satellites to block out cosmic X rays that might distort digital communications. The filter converts X rays into visible light by using an optical down conversion process to lower the energy of the photons. This will prevent your digital "film" from being overexposed by too many different wavelengths. And though it's technically not illegal, you can't buy the material from any reputable store. (We also wouldn't recommend bringing the stuff with you on your next trip to North Korea.) If you do manage to track down a small piece, here's how to mod your camera and give it superpowers.
Step 1: Building the X-Ray Vision Camera
Time: A Couple of Afternoons
Cost: Over $18
Difficulty: Hard
Parts List
  • CVS Disposable Digital Camera (CVS Pharmacy; $18.00)
  • X-Ray Beryllium Material (Google It)
  • Wire, solder, glue, diffraction pattern sample (i.e., your hand)
Step 2: Rip It a New One; Disassemble the Camera
Remove the case back panel from the CVS disposable digital camera. Locate the batteries and take them out of the camera. Carefully lift the camera's circuit board out, exposing the lens/shutter assembly. Remove this assembly for gaining access to the CMOS sensor.
NOTE: Do not touch the flash capacitor. This component can maintain a strong and painful charge for extended periods of time. Use extreme caution when opening this camera and use protective gear, including rubber gloves, rubber-soled shoes and rubber-handled tools.
Step 3: Scalpel; Cut Your Filter
Use a very sharp razor blade for cutting a 3mm-square piece of the Beryllium material and be careful only to touch the edges--it smudges easily.
Step 4: Dress It Up; Cover the Sensor
Place the filter over the CMOS sensor, use a tiny drop of glue in two of the corners to hold it in place, reinstall the batteries, and reseal the camera.
Step 5: Oh, Behave; Look Around
Turn on the camera, point it at your hand, and fire away. Because the filter is only over the sensor, you won't see the effect looking through the viewfinder, but you will see "something" when you download your pictures. Get ready to amaze your friends. Go to Camera hacking forum featuring John Maushammer for instructions on modding your disposable camera for re-use.
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
    • Audio Challenge 2020
    142 Discussions
    ElvenChild
    ElvenChild
    7 years ago on Introduction
    Maybe It's just my inexplicable talent and ability to unintentionally hurt myself, but step 3 looked like it said "Step 3: Scalpel; Cut Your Finger".
    Here is a cheaper way to get true X-Ray:
    http://www.houseoftheunusual.com/stock/bestsellers/page6.html
    Buy the real X-ray glasses! They will do the job at a very low price...
    use code# ind77 it will give you future discounts.
    Light_Lab
    Light_Lab
    9 years ago on Introduction
    Some consideration must be given to the fact that this Instructable was released to coincide with April the 1st. I am sure Popsci was just making a joke.
    (1) Beryllium is used as an X-ray window material as it passes X-rays but not visible light. It is readily available from X-Ray equipment suppliers. Without a special phosphor layer it could not act as a down converter.
    (2) You also need a strong source of X-Rays; Solar X-rays aren't enough. Think about if X-Rays of any strength were coming from the sun it would make any form of photography virtually impossible.
    (3) The lenses of a digital camera cannot focus X-rays. In fact X-rays are usually made as contact prints to avoid the problems of focus.
    (4) The image is obviously faked, the bones are in the wrong places, the ring on the finger would appear black in an X-ray. I believe he deliberately wore it as a clue for the joke.
    A good joke, have a chuckle and move on.
    BTW The technique that ELF et.al. is referring too is using infra red or near infra red. This is an excellent area to experiment in with a converted digital camera. Despite all the rumors only a certain range of synthetic fabrics are completely transparent to IR. Nevertheless many food colorings eg cola drinks, soy sauce etc are transparent to IR as are many plastic coloring agents. It is also excellent for penetrating smoke and other aerosols.
    ELF
    ELF
    13 years ago on Step 3
    Hah! That's a normal IR block filter, replace it with a piece of (over-)exposed color film, and you got a camera that can see through some things like thin fabrics, like bathing suits (Making you a creep if you tried it) but also through coke (the brown liquid stuff you know :P) some cheap sunglasses, skin to some extend (your bloodveins will "pop out" more viewed through the camera), and will also block the light from LCD monitors, because they don't emit any IR light, so it will look like it's turned off... Anyway, try that instead :)
    techno guy
    techno guy
    Reply 9 years ago on Step 3
    Where do you get an overexposed piece of color film.
    ELF
    ELF
    Any smaller photo store where they develop film.
    It's usually a wasteproduct from the start and end of a roll of film.
    Kaiven
    Kaiven
    Reply 12 years ago on Introduction
    over exposed... like what? a diposable camera's film left in the sun?
    tubbychick3n
    tubbychick3n
    Reply 11 years ago on Introduction
    just go find some old film negatives, usually before the roll of pictures, there's about four sections of all black.
    usb key
    usb key
    if i used a camera and i got the negatives i can use those? could i just look through them or would it have to be a camera
    tubbychick3n
    tubbychick3n
    It has to be in a camera. If only it were that easy. I wouldn't ruin a good camera if i were you. I put it into an old eyetoy (ps2 webcam-type thing) that i use as a webcam for my computer and it worked great. It's actually quite fun to mess around.
    usb key
    usb key
    but that would still be a web cam. can i get a disposable camera and use that or does it have to be night vision (i saw some youtube videos)?
    tubbychick3n
    tubbychick3n
    I guess there might be some digital disposable cameras that you could use, but i don't think the disposable film ones will work like you're thinking.
    usb key
    usb key
    do the negatives need to be on a camera lens? and can i just take pictures, develop negatives, and use those?
    tubbychick3n
    tubbychick3n
    Yep. The next time you go to develop pictures, just take the darkest part of the film (negative) and find the sections where no pictures were( it should be extremely dark in that area) and use that. That's what i did for my eyetoy.
    Kaiven
    Kaiven
    ORLY?! someone finally tells me what i wannt to know! xD Thank you
    tubbychick3n
    tubbychick3n
    no problem. i have already done this with one of my eyetoy cameras and it works great.
    ELF
    ELF
    Yea, for like, a second or something :P Till it's "black", won't more than a second or two :)
    ELF
    ELF
    You're welcome :) Remember, these films are very photosensitive. On a sunny day you might only expose it for like 1/125 to 1/500 of a second.. ;)
    AnarchistAsian
    AnarchistAsian
    ummm... is this dangerous? or is it just x-rays already present in the enviornment that you are viewing with?
