Weekly Project: Noggin Logger--A Wearable GPS Data Logger
42,114
66
14
Introduction: Weekly Project: Noggin Logger--A Wearable GPS Data Logger
Where have you been? And, where did you go today? While words can aptly describe your daily activities, a picture can communicate around a thousand words, or something like that. Better yet, take that picture and wrap it around a fistful of GPS data and now you're really talking.
The GPS Logger V1.1 kit from Spark Fun Electronics (#GPS-00671) is a complete plug-n-go solution for logging every step you take during a day, a week, or, even almost, a month (in KML logging mode). Just pop in some batteries, flick the teensy switch, and within a couple of minutes you'll know exactly where you're standing when you flicked that teensy switch.
Based on the Lassen iQ GPS module by Trimble, roughly every second is recorded with the Spark Fun Electronics GPS Logger V1.1. You can select between The National Marine Electronics Association (NMEA) data or Keyhole Markup Language (KML) data. The latter has been uniquely massaged for assimilation directly into Google Earth coordinates format.
If you're a data miser, though, you'll probably opt for logging the NMEA data. As such, your GPS plate will be full; very, very full of data. Specifically, there are two lines of GPS data recorded every second with the GPS Logger V1.1:
$GPGGA,220536.00,3024.9664,N,08849.1198,W,1,04,3.70,00023,M,-026,M*52
$GPVTG,236.3,T,235.2,M,000.0,N,000.0,K,A*21
Where:
  • $GPGGA-Global Positioning System Fix Data
  • 220536.00-Coordinated Universal Time (UTC)
  • 3024.9664,N-Latitude
  • 08849.1198,W-Longitude
  • 1-GPS Fix
  • 04-number of satellites being tracked
  • 3.70-horizontal dilution of position
  • 00023,M-altitude above mean sea level in meters
  • 026,M-altitude of mean sea level in meters
  • *52-checksum
  • $GPVTG-velocity/track made good
  • 236.3,T-heading in degrees
  • 235.2,M-magnetic heading in degrees
  • 000,0,N-ground speed in knots
  • 000.0,K-ground speed in kilometers per hour
  • *21-checksum
Armed with your prodigious pile of GPS data, you can view your whereabouts inside Google Earth. But getting the raw data into a brag-worthy picture could take longer than the trip you just logged. Some deft fingered text manipulation with an industrial-strength text editor (e.g., BBEdit) and Microsoft Word can convert your NMEA data into useable KML coordinates in a matter of minutes.
So where can you carry this fancy GPS logger? Well, use your head, man; literally. The GPS Logger V1.1 will easily fit inside the top peak of a baseball cap. Just route the embedded antenna out through one of the cap's ventilation holes and you'll be loggin' in no time.
Ja, das ist der Noggin Logger.
Teacher Notes
Step 1: Build the Noggin Logger
Time: 30 minutes
Cost: $153.70
Difficulty: Easy
Parts List
  • GPS Logger V1.1 kit from Spark Fun Electronics ($150.70 #GPS-00671)
  • Velcro Brand Sticky Back Tape 3-feet x 3/4-inch ($3; craft center)
  • scrap fabric swatch (FREE; scavenged)
  • baseball cap (FREE; repurposed)
Step 2: Assemble the Logger
The folks at Spark Fun Electronics have made the assembly of the GPS Logger V1.1 kit pretty much foolproof. Slip in the coin cell battery, insert the blank SD memory card, snap four AA-size batteries into the holder, and attach the battery holder plug to the PCB battery connector.
Step 3: Cap It
Route the embedded antenna through one of the small eyelet ventilation holes in the top of the baseball cap. Plug the antenna into the bottom of the Lassen iQ module. Snap the module onto the PCB connector.
Cut an oversized round piece of scrap fabric for the liner of the baseball cap. This piece of fabric should be big enough to cover the entire GPS Logger V1.1, plus add a seam allowance of 5/8-inch around the perimeter of your scrap. Slowly roll this seam allowance toward the inside of the fabric swatch, press it with an iron, and stitch it down.
Line the inside of the cap's peak with some Velcro Brand tape hooks. Make sure that you have ample hook pieces for holding the GPS Logger V1.1 and the fabric liner. Attach Velcro Brand tape loops to both the underside of the GPS Logger V1.1 battery holder and the bottom of the fabric liner. Press the logger into place, then install the fabric liner.
Step 4: Get Goin'
Pull the fabric liner aside and flick the power switch on the GPS Logger V1.1. In about 2-5 minutes, you'll be logging NMEA GPS data. Don't just stand there, don your chapeau, and get loggin'.
Step 5: Data Crunching
At the conclusion of your journey, pull the fabric liner aside, turn off the power, and remove the SD media card. Use any SD media reader to transfer the files onto your computer. The data is platform independent so you can read and massage your GPS content on any computer that can read an SD media card. You should have at least two files on your properly logged card:
  • GPSx.TXT
  • GPSCON.TXT
The GPSCON file is used for selecting either NMEA data (i.e., "NORMAL") or KML data (i.e., "KML"). The other file (or, files; files are sequentially numbered GPS1, GPS2, etc. for each activation of the logger's power switch) contains the GPS data. Now it's data crunchin' time. Here are a couple of shortcuts and tricks that you can use with BBEdit for quickly trimming your data fat:
  • Delete lines that contain "$GPVTG" - removes all velocity & heading data
  • Find/Replace "," with tabs
  • Use MS Word for converting tabbed data into a table
  • Move/delete columns
  • Convert table back to text
  • Back in BBEdit, Find/Replace tabs with ","
  • Delete Line Prefix "0"
  • Insert Line Prefix "-"
  • Move those decimals with wildcards
If you'd like to retain as much GPS data as possible and disdain the KML data mode, you can reprogram the GPS Logger V1.1 yourself. Spark Fun Electronics has the firmware and an LPC Serial Port Programmer for getting the job done.
Step 6: This Is Where I've Been
Write a KML shell for holding your coordinates, altitude, and other pertinent GPS data. Consult the KML 2.1 Reference for adding appropriate tags. Insert the data, fire up Google Earth, and open your KML file.
Now, THAT'S, where I've been.
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    14 Discussions
    cgrrty
    cgrrty
    6 years ago on Introduction
    Good job ,and i think smartphone has gps can do that too.
    kh319
    kh319
    9 years ago on Step 6
    Nice to see some fellow south Mississipians
    Warholm
    Warholm
    9 years ago on Introduction
    How were you travling for the trip shown?
    Light aircraft? ballon?
    Or is the path just not visible on Goole earth...
    And what about when you get to the sea ???
    Warholm
    Warholm
    OK on closer inspection
    the actual route end points are offset from the stated endpoints :-(
    chris.brent
    chris.brent
    10 years ago on Step 1
    #GPS-00671 Doesn't seem to exist at sparkfun anymore. Did they replace it, I can't see anything similar?
    royalestel
    royalestel
    12 years ago on Introduction
    Now how can we make one of these out of an old cellphone? . . . . . . . . still thinking . . . .
    johngomm
    johngomm
    Reply 12 years ago on Introduction
    I was under the impression that most cell phones have to communicate with the network to get GPS readout (something to do with outsourcing the computations and increased accuracy with cell tower triangulation) so I don't think old cell phones are the way to go. I want someone to come up with a gps device that is the size of my thumb, has orientation sensors and a timelapse camera. Now that would be interesting to put in your hat. Wouldn't that be the ultimate webcam blog. Might be a little dull most of the time though. Handy for writing your memoirs.
    jongscx
    jongscx
    Reply 11 years ago on Introduction
    Look up the bike-cam. It's built out of a newer nokia phone that has GPS already built in, and is pretty much just a java applet, but it essentially automatically uploads pictures to flicker with the GPS data. they they wrote a custom applet for google maps that shows your pictures in relation to the location on the map... pretty awesome but expensive stuff...
    Advocat
    Advocat
    Can I use an old gps reciever from ebay?
    jongscx
    jongscx
    you COULD... but you'd have to find a way to harvest the NIMAE data, translate it into some format, store said format onto a storage medium, and have it do that per set time interval... If you didn't know the above already... it's cheaper to buy the kit...
    ongissim
    ongissim
    You should waterproof the cap, just in case you get stuck in the rain! ;-)
    ironsmiter
    ironsmiter
    Nice... expensive, but nice :-) Now, you need to make a google sketchup avatar, and place it in your favorite "permanent location" say, standing outside the instructables webhost building? Just tell google maps that you're an outbuilding :-)
