Weird Stool
Introduction: Weird Stool
About: Royal Academy of Arts The Hague - Master Industrial Design
Weird Stool is a modified version of Twistab Original open source stool which I modified and cut through CNC milling machine in Royal Academy of Arts, The Hague. This is the steps I made to create it.
Teacher Notes
Step 1: Introduction
To make my weird stool, I downloaded the manual and the open source file of Twistab original, you can find the manual here to do the same.
Step 2: Re-design
After downloading the files, I started modifying the original stool with Illustrator by randomly dragging the lines around to obtain a funnier and weird shape, until I was satisfied with the result. Here is the illustrator file which I obtained.
Step 3: Final Editing for CNC Milling
To prepare my file for the CNC milling, I exported it on Rhinoceros and adjusted all the layers according to the instructions you can find on the manual. All the different activities the CNC milling machine has to do have to be on different separate layer. Here is my file, with separated layers and everything.
Step 4: Milling
After the file was ready I sent it to the machine for milling. This took a couple of hours because I was using the machine with other people. The material I used was a cheap plywood board, 30mm thick.
Step 5: End Result
After milling, I took out the different parts and assembled them. I polished the edges with sanding paper and cleaned the leftovers left by the bridges. This is the end result of my weird stool.
Be the First to Share
    • First Time Author Contest
    • Space Challenge
      Space Challenge
    • 3D Printed Contest
      3D Printed Contest
