What Is Light? Wave or Particle? Examining the Wave-particle-dualism...
6,049
49
13
Introduction: What Is Light? Wave or Particle? Examining the Wave-particle-dualism...
Hi!
I want to start with a question. What is light? When you go around in nature or somewhere else you will get in contact with typical waves like in a lake or with particles like hail. But what is light?
The so called wave-particle-duality, a special statement of the quantum physics, says that the things around us are both, particle and wave.
What would you expect, when you think they are typical particles? You may say, that they can be detected individually at a choosen place. A particle can hit you or passes by, depending where you are.
Contrary to that a typical wave isn't at just one place. A wave is in an area at the same time. And what is further typical for a wave? Interference. With waves you can often see interference patterns. When a wave hits a grid, than you'll see patterns of maxima and minima behind on the screen. With particles you will never see that.
In the following pages I'll show you, that f.e. light is both, particle and wave...
Step 1: The Parts You Will Need
First of all you'll need a light-tight housing. I bought a large one from amazon. Unfortunately I found out, that the housing itself let light into. When I held a flashlight to a side of the housing, the counting rates of the photomultiplier increased dramatically :-(... That's why I had to stick it with black tape
To lead out the micrometer of the linear stage was not easy too. I used two-components glue.
Step 2: The Heart of the Experiment, the Photomultiplier
A photomultiplier is a extremly light-sensitive device. It can even count single photons. Usually a photomultiplier needs high voltage to accelerate the electrons between the dynodes. At the output you get a short voltage-pulse (nearly) everytime a photon hit the photo-cathode at the front of the photomultiplier.
I used the Hamamatsu 5773. The advantage of this special type is, that you don't need a separate high voltage power supply. The high voltage is created inside just with the 12V input. And it's small too. A further benefit.
Step 3: The Electronics
For the pulses coming from the photomultiplier you need a simple amplifier and a monoflop. The amplifiere turns the pulses of sufficient heights just around (gain = -1) and the monoflop creates longer pulses for the counter when a photon was detected. To avoid that the counter reacts to noise, the circuit consists of a comparator. The level, above the pulses are counted, can be chosen with a potentiometer.
Step 4: The Source of the Photons
For the photons I bought a 5mW dpss-laser from ebay for 10 USD. The wavelength is 532nm. But you can't put the laser inside the housing and turn it on. The photomultiplier would be destroyed because of the huge amount of photons. A 5mW laser emitts about 10 000 000 000 000 000 photons per second! Therefore you have to weaken the laserbeam. A so called neutral-density filter is the part you'll need. I tried several combinations of filters with the optical density 4.0 and 1.0. At the end I use 2 layers of 4.0 density. This weakens the beam by the factor 10^-8.
Now you could say, that still 10^8 photons hit the photomultiplier per second. This isn't right. Behind the grating the beam is splitted into many many beams. So the photons are splitted too. And another important point is, that the window of the photomultiplier is being covered with tape. Just a very small slit is left and therefore the number of photons detected per second is low enough for the counter (for a intensity-maximum around 12000 photons/minute).
Step 5: The Whole Setup
The whole setup consists of the housing with the photomultiplier and the laser, the amplifier+monoflop and the counter. For the electronis I need a symmetrical +12/-12V power supply. The inside of the case is covered with black foam rubber to minimize the scattered light.
Step 6: The Results
So, the experiment has to come to an end. What do we expect to see/measure? If light consists of particles, they could be detected with the photomultiplier. But particles woun't create diffraction-patterns behind the grating. Only with a wave you will see interference-patterns.
But when I turned on the laser and moved the photomultiplier I could hear the speaker of the monoflop. Every click stands for a registered photon. So I detected single photons, single particles. But the number of particles detected within one minute changed while moving the photomultiplier. I got positions with higher counting rates and positions with lower counting rates. This is typical for a wave.
Conclusion: Light can be detected like single particles, but they carry information of an wave with them. Therefore I got diffraction-patterns and the counting-rate increases and decreases behind a grating. Voil'a, I proofed one statement of the quantum physics, the wave particle duality. Light is particle and wave at the same time....
Maybe you're interested in some of my experiments, here's my youtube-channel: https://www.youtube.com/user/stopperl16/videos
And last but not least: I'd be very happy if you could vote for me in the optics-contest. Thank's a lot...
Optics Contest
Optics Contest
Be the First to Share
    • Puzzles Speed Challenge
    • CNC Contest 2020
      CNC Contest 2020
    • Secret Compartment Challenge
    13 Discussions
    bigredox
    bigredox
    1 year ago
    "Current commonly accepted physical theories imply or assume the photon to be strictly massless." Easier to cut & paste from Wikipedia. keep trying. And Maxwell did all of the scientific heavy-lifting for Einstein pre-quantum theory.
    magiceye
    magiceye
    1 year ago
    Is it possible to also do an experiment to show Heisenberg Uncertainty Principle,in quantum mechanics where by if you narrow the slit the uncertainty of a particle position increases.
    taracary
    taracary
    Reply 1 year ago
    No... Particle position is simply a function of probability and interference geometry. Heisenberg is a statement about the precision of two complementary physical properties, (ie: you can't know it's exact position AND it's exact momentum at the same time). Here, he is only observing the position.
    T L Cary
    T L Cary
    1 year ago on Step 6
    Credit where credit is due:
    Double-slit experiment: Thomas Young, Circa 1801
    Allan BrunoP
    Light must be pure wave. No? -Then explain Faraday cages ability to always block. :)
    Kwitzats
    Kwitzats
    Reply 1 year ago
    for a Faraday cage to work the holes must be smaller than the wavelength. Light has a really small wavelength most of them let in light just fine.
    stoppi71
    stoppi71
    Reply 1 year ago
    A Faraday-cage avoids electrical fields to go through, not light (photons)
    RoboDon2
    RoboDon2
    1 year ago
    I have always thought about it like this: Pour pingpong balls on the swimming pool. Balls are particles. Jump in and make waves. Now you have waves of particles. Duality simpilfied?
    Kwitzats
    Kwitzats
    Reply 1 year ago
    Hi, no it is not that simple. A single ping pong ball cannot interfere with itself. a quanta of light can. Observation is what collapses the duality and not only light exhibits this wave duality large carbon molecules have been known to do the same thing. reality is just much much wierder than is intuitive.
    foxpup
    foxpup
    1 year ago
    Nicely done experiment. Its experimental "stories" like this that give us the real truth about light, whether we are making interference patterns or counting pulses in a gamma-ray triggered Geiger counter. Is light a particle or a wave? I say neither. True waves (particles too) are a mathematical concept and do not really exist in the real world. When we observe light, we see a behavior that is unlike either. Consequently, it is something else. That doesn't disturb me. It just causes me to acknowledge that the universe is much more mysterious than many are out to make it and that is where the beauty and wonder is. :-)
    smooth_jamie
    smooth_jamie
    1 year ago
    interesting! This is a cool way to quantify the amplitude of the constructive / deconstructive waves at the fringes. I wonder how accurately you could measure the wavelength of the light source?
    Gadisha
    Gadisha
    1 year ago
    Interesting experiment, thanks for posting :)
    stoppi71
    stoppi71
    Reply 1 year ago
    You're welcome...
