This is my first modeling
Teacher Notes
Step 1: STEP 1 Build the Base Board
1.
The base boardcontain contain 3 components
2.
First,choose a long board that is 70cm long and 20cm wide
3.
Select deflector tube, adjust the angle to 70cm and the inner and outer diameter to 20cm. So connect it to the long board
4.
Copy another deflector tube and use align to connect to the board
5.
Finally,join the coeners with two dome roofs.
Step 2: STEP2. Add Board Locks and Pulley
1.
Pulley backplane has multiple components.
2.
Choose a board that is 15cm long and 13cm wide.
3.
A lot of components spliced into pulleys
Step 3: STEP3. Finished Product
1.
Add some decoration
2.
Results display
Skateboard Contest
