Introduction: Wine Box Flat-Pack
Step 1: Cut-Out Template
Step 2: Cover Two of the Polystyrene Cut-out Plates With Magnetic Tape
Step 3: After Covering Two of the Polystyrene Cut-out Plates With Magnetic Tape, Draw the Folding Template on the Fabric!
Step 4: Overtape the Four Panels With Carpet Tape. Tape on One Panel a Magnet, This Will Make the Closing System of the Box Stronger!
Step 5: Use Textile Glue Between the Panels. Then Peel Off the Tape
Step 6: Use Something Soft to Press the Panel Form in the Fabric. Use Lots of Pressure and Place a Wood Panel on Top!
Step 7: The Result
Step 8: Cut the Fabric at the End of the Plates. Glue the Remains Together With Super Glue!
Step 9: Place the Foldable Plates in the Middle and Tape the Plates With Carpet Tape on Each Side.
Step 10: Place the Foldable Plates in the Middle, Then Glue Them Between Two Pieces of the Fabric at the Same Dimensions As the Outside Box Cover!
Step 11: After You Glued the Two Pieces Together Place Them Between Two Wooden Panels. on the Other Side Put Something Soft Where You Want the Profile to Pop Out!
Step 12: Result After Pressing the Fabric!
Step 13: Cut the Fabric Until the Edge of the Plates. Afterwards Glue Them Together With Super Glue!
Step 14: Align the Plates With the Big Plates. After Aligning the Plates Use a Little Bit of Super Glue and Glue Them Together!
Step 15: Result Bottom Plate
Step 16: Cut the Other Plates and Paste Both Outsides Together With Super Glue!
Step 17: Align the Plates With the Big Plates. After Aligning the Plates Use a Little Bit of Super Glue and Glue Them Together!
Step 18: Use the Spacing Between the Upper Foldable Plates As a Carrying System. See the Result!
