Wood Pot Made Out of Rings
About: I’m thirteen live and work at a hardware store. And build stuff when I feel like it. Oh and write Instructables about them. And now posting YouTube videos.
Ok, I'm not sure where the idea came from. Maybe when I was looking at the planter challenge somebody was standing behind me and put the idea in through my ear? Anyway let's grow some ear plugs. It's really simple.
Supplies:
  • 1x6 squares
  • Scribe and pencil
  • Drill and drill bit
  • Scroll saw
  • Sander
  • Stain
  • Paint brush
  • Steady hands
Teacher Notes
Step 1: Watch Video
Step 2: Cut
Get your piece of 1x6 and cut it in to a square. That's 5 1/2" x 5 1/2" for most 1x6's. I'm assuming that if you used hardwood it would be a lot better? Maybe? If you tried let me know in the comments.
Step 3: Scribe
I used a scribe to draw the circles. Not perfect but I don't really care because it is just pine.
Step 4: Drill
I used a drill bit the same diameter as the scroll saw blade. In this case a 1/8 drill bit. Drill at every line. Make sure not to drill to close to other lines.
Step 5: Scroll Saw
I used a scroll saw to cut out the rings. Tilt the table to 5 degrees. Then cut around 90 percent of the circle and leave a tab to hold it on. Once you finished cutting all of them go around and cut the tabs.
Step 6: Sand
I used a power sander to sand down the rings.
Step 7: Stain
This is optional. It's pretty obvious what to do here. Let it soak in for a couple of minutes then wipe the excess off.
Step 8: Super Glue
I used some super glue to hold the rings together once they where in the right position.
Step 9: Figure Out What to Put in It
You could put anything in it: fruit, plants, seal it off to make a bowel, anything! But in this case we are growing HIGHLY valuable earplugs.
If you could follow, subscribe and vote it would be much very appreciated.
Planter Challenge
Planter Challenge
Be the First to Share
    • CNC Contest
      CNC Contest
    • Teacher Contest
      Teacher Contest
    • Maps Challenge
      Maps Challenge
